Turbo Tahoe?
09TahoeLT
Did everything mount up no problem? Like the inner cooler? I saw some people having to make there own mounts for it
ibfreeman88
ibfreeman88
Chesapeake, VA
The kit comes with brackets for the intercooler which worked well. But to be honest if I were do it again I'd probably go with the trick performance kit for simplicity and what seems to be more quality parts in regards to V band clamps and T bolt clamps etc.
mikeyss
Longmont, Colorado.
I think the 2009 Tahoe had the option to have a 4.8, if it was 2WD. The 4.8 would have had a 4L60. I found this as well:
2009 CHEVROLET TAHOE SPECIFICATIONS
  • Price (MSRP)
    $ 36,965
    Value Rating
    N/A
  • Engine Name
    Engine: V8, 4.8 Liter
    Transmission Name
    4 Speed Automatic w/Overdrive
  • Trim
    LS 2WD
    Class
    Full-Size SUV
  • Horsepower
    295@5600
    Standard MPG
    14 City / 20 Hwy
  • Body Style
    SUV/Crossover
    Drivetrain
    2WD
  • Fuel Type
    Unleaded Regular
    Seating Capacity (Std/Max)
    6/9
ibfreeman88
ibfreeman88
Chesapeake, VA
Someone went through a lot of work to backfit the 4-speed in there then, even the TCM had to be changed, should be a T43.
My truck does in fact have a 4L60e and it came from GM that way. M30 on the RPO codes.
ibfreeman88
ibfreeman88
Chesapeake, VA
Definitely an odd one! I know the 09 trucks split the year between the 4L60 and the 6L80 (I was a tech and a parts guy for GM) and every 09 Tahoe 5.3 had a 6L80, while the 4.8 2WD only had the 4L60. I bet it's a very early 09.
I was really hoping I was going to get lucky lol so then I could skip the 4L80 swap and go straight to a cam and converter lol. But I'll just make due until I get all the trans swap parts in hand.
Odd and unexpected! Tenth digit in VIN is "9", designating it as a 2009. "LMG" is the 5.3 and, as you already know, M30 is the 4L60E. Oh well, with enough power and with a good shift tune, you won't miss the other gears so much.
Well I'll be a monkey's uncle! Never heard of that before. I read where the pickemups started out 2009 with 4-speeds but not the SUVs. Guess it might have had something to do with it being a PPV maybe?
GT4 = 3.73 gear, that's good!
992dr
Eastern N.C.
I hope I don't sound like an imbecile but, How the heck do you guys read that?
Is there a book on how to read RPOs?
ibfreeman88
ibfreeman88
Chesapeake, VA
Haha you don't. I had no clue about what it even was until earlier and then google once again filled me in on some new useful tools. Just search RPO code for what ever you'd like to know about your Tahoe etc and in most cases something will surface.
Ask me how long a stock 4l60 lasts after boost is added. About a hundred miles in my case. Unfortunately with my NV249 TC the custom adapters are no longer available for an 80e swap so I went with a Performabuilt level 3 60e and tci triple disc billet converter. So far so good.
ibfreeman88
ibfreeman88
Chesapeake, VA
It's crazy some people have the worst luck where they don't last anytime and other people have them last way longer than anyone would expect. The guy who's tuning my truck didn't seem to concerned when I told him it had a 60e and I knew that was the weak link. And that I just wanted it to run good and be able to get out of its own way. I didn't care about how much power it made just wanted to enjoy it until I get all the trans stuff squared away.
eand28
Pennsylvania
It's impossible to not drive it hard once in awhile after you add boost lol. Kinda addictive.
True. I had the trans beefed up when I got it rebuilt a few years ago. Shifts awesome. and when I dropped my new engine in 2 winters ago, I pinned the crank, so I just need boost now :shrug:
ibfreeman88
ibfreeman88
Chesapeake, VA
Valid point lol but it'll be just as hard to have to spend another $2k or more in the next few months. I told the ms. that I would take a break and take care of stuff around the house after it's running and tuned.
Do you have a thread on here for the one that you turbocharged?
I went with a supercharger. I have a huge ass build thread for the whole truck but here's a link to the part where I started on the blower. I've done about everything I can do to the 02 except bag it. As far as the engine, I did a cam, roller rockers, dual valve springs, and headers as well as a Whipple. Like I said, addictive. At the bottom of my posts are links to both my builds; if you're on a phone you have to turn it sideways into portrait mode to see my sig and the links.
https://www.tahoeyukonforum.com/thr...nali-build-thread-aka-the-beast.83457/page-52
ibfreeman88
ibfreeman88
Chesapeake, VA
Well cut work short today and went and wrenched on the truck for a few. Got the vaccum lines run as well as my fitting in the pan for the return. Started extending my wires for my MAF sensor but I need some more materials. Just waiting on my fitting for my oil feed and it's just about complete aside from fluids.
TejasPitt
