Tonyrodz's Tahoe Build Thread
ArcticYukon
The White Yuke has been superseded by a Red Hoe
Dry Ridge, KY
I got some nice chevy chromed center caps today from a fellow member. I wanted to put them on my 22's, but they're just a hair too small.
View attachment 200966 View attachment 200967
Anyone have any ideas to make them work? I think the black wheels will look good with the chrome caps, even tho I don't have any other chrome on the Hoe.
You might be able to wrap some wax paper around the tines of the cap, tape the cap in place in the hole, then flip it upside down so the face of the wheel is facing down. Get some JB weld and fill the cap in that way. Then, you'd still be able to remove them if you want to, but it would snug it up.
You don't think they'll break if I need to pop them out?
ArcticYukon
Dry Ridge, KY
Shouldn't.... wouldn't wind up being any different than a snug-fitting center cap. All you're doing is filling the gap between the center cap and the center opening of the wheel... the cap with the wax paper is just there to act as a cast while you're pouring in the JB weld.... wax paper will keep it from sticking to the cap.
08grey
Use black high temperature rtv sealant Tony. The same you would use on a Trans pan. It will fill the gap and won't become brittle under the brake heat. Will be invisible when it dries I promise.
Sent from my SM-G950U using Tapatalk
I'll give it a shot.
I was able to get the complete driver side switch panel from an Avalanche that has the power fold mirror option.
Bezel was the same color too. All switches worked except for the up position for pass side rear window. I took it apart to clean the contact, works great now.
So since I had to take it apart, I figured I'd take both pieces apart, just to compare the differences internally.
It was much easier to add stuff like this in the NBS. My NNBS Silverado takes a damn miracle to enable power fold mirrors. The harness isn't even there plus a few other hoops to jump through.
Nice! Do those mirrors also aim down to the ground when you reverse? My bro-in-law's ex had a NBS Yukon that would do that when she would reverse.
If you have the DIC, then you can program them to do that. Mine is the LS model, so mine is pretty basic. I have the switch now, so now I need to get some power fold mirrors. Mine don't aim down when in reverse because I don't have the DIC to program that feature.
ArcticYukon
Dry Ridge, KY
Ah ok. Yeah ours is the LS also, so it wouldn't either. It's funny though, the truck is still pretty loaded up with features. Leather, 6-way power on driver and passenger seats, 3rd row seating, power/heated mirrors, tow package... BUT, I don't think the "reverse" function on the mirrors was even available on the '00s.
95escahoe
The reverse function is on the NBS trucks my Escalade has it, I have it turned off but it’s there in the DIC
The power of the almighty DIC. Y'all just need to get yourselves a DIC and you'll have all the control you're missing. I enjoy using my DIC. It does more for me than I need it to. It got me in trouble a few times, but that was before I learned how to properly use it's features. Ever since my DIC and I became one with each other, our drives have been drama-free. Jenn never did learn how to use the Tahoe's DIC and I had to coach her over the phone a couple of times. But she drives a different car now that doesn't have such a DIC.
Spoken like a true DIC user. Sounds like you needed alot of practice to learn how to use the DIC.
I did! It has four areas to press on and each one does something different when you press it there. Even then, some of features of the DIC won't work unless you have the lever in the "P". I usually have the lever in "D" but I can stop and put it in "P" to have unbridled access to all that my DIC has to offer.
Is the NBS similar to the NNBS where it has the harness for the DIC behind the instrument panel bezel and all you need is the button assembly and the bezel with the spot for the buttons?
Wish I knew. I'd really like to add a DIC to the Hoe. So many more options:D
jackal78
