Rocket Man's 2008 Bagged CC Silverado Build AKA "THE MACHINE"
The Tech 2 has already paid for itself. It helped me to find 55 cents under the front passenger seat. Actually, it cleared the dtc's for my ABS and the dic message for that problem hasn't returned. But back to that spare change....I was trying to figure why my airbag light was on and the dtc's it came up with pointed to the passenger presence module. It lets the SIR system know if the passenger airbag should be turned on or not. I subscribed to alldatadiy and was reading that I needed to either zero the module or check the wiring to it so I tried to zero it. No communication, so I looked at the wiring and under the front passenger seat, I found a connector on the seat with nothing plugged in. I knew before that this truck doesn't have electric seats or airbags in the seats so I never thought to look for wiring problems at the seats in order to fix an airbag light. I pulled the seat and found the harness pinched under the carpet. It looks like somebody reinstalled the seat and when they bolted it down they pinched the harness under the carpet where they couldn't see it so they must have thought nothing went to that plug so they just left it. Anyway, the airbag light is off and I cleared the dtc's from history. I would have bet on it being a front impact sensor since that's a known problem. It didn't cost me anything to fix this, in fact it paid me 55 cents lol.
NathanJax
Vacation Nathan
Jax, Fl
Love the truck and nice to see a build thread on it.
Duh. I feel so stupid. It was the TCM battery fuse missing. I'm not sure where I put that one....into an unused spot that now has a fuse lol. What an idiot.
:lol2:
Just doing some minor stuff today; the 1 1/8" plugs came in so I popped a couple in the parking assist sensor holes in the rear bumper so that looks way better. Then I pulled the front wheels to clean the insides of them and found the bottom shock bolt on the passenger side was really loose. I took a look at the driver side and found it had fallen off. The PO had paid a mechanic to replace them a week before I bought the truck and I guess he doesn't believe in tightening things. The truck had a rattle depending on what height it was and the dude had told me he just had the exhaust welded on and it started happening right after that so he thought I just needed to bend the pipe away from the frame. Which never made sense to me because the ride height shouldn't have made a difference. This was the problem.
05Single
afraid of the dark
View attachment 192757 View attachment 192758
Jesus Christ, like one of the most basic pieces in a vehicle to install. How does one **** that up!!!
Luckily no harm was done but I'd still call the shop and give them an ear full
Oh the PO is, believe me. I texted him the pic. He said he's never taking anything there again, and he's gonna call them and *****.
05Single
afraid of the dark
Last thing a shop needs is the owner of a badass build like this to put a shop on the ban list.
Oh you're mad at a shop and you drive a prius? Wont take you seriously.
You're mad at a shop and you drive a fully custom bagged vehicle? I'll value your opinion lol
While I had my front wheels off today I noticed it needs rotors and pads. I checked online to make sure the NNBS upgrade parts I had left over from my Denali would fit and they will. I'm glad I didn't sell them when I did my Wilwoods. The CC's rotors are grooved and pads are down to nothing. The ones I have are about a year old and the pads are EBC Green Stuff with 75% left. Plus I have the stainless steel hoses. The calipers are a year old too so I'll probably change those too. I'm still deciding on if II want to paint them black instead of the red they are. Too bad I can't use the rear rotors too but the CC has drums back there.
Hmmm....rear disc brake conversion??? It's been done but seems like a lot of work.
THE YETI
Director of Operations
South FL
Not really. Just swap the axle out. Find one out of a NHT package Silverado with the 12-bolt rear.
On another note.. that lower shock mounting tab looks like it’ll snap off the first bump you hit. No gussets?
I have a narrowed rear end ,don't really want to mess with it since the axles are custom. That mount is solid as hell. The frame they built as well as all the other fabrication is quality.
inmypassatlife
Yeah and he won't explain himself; I've sent 2 PM's and no answer. Oh well I guess he doesn't have anything to say after all.
Wish I would have screenshot my main page right before I answered you just 5 minutes ago. I rarely pay attention and the ones on this board I do care about getting in touch with have my number.
THE YETI
South FL
Hmmm... cutting the axle tube down and putting your inner shafts in shouldn’t be that expensive.
But i believe Baer brakes makes a conversion for it too.
Would be cool to run discs in back with some large calipers. :)
kbuskill
NE. FL.
Just slide your axle shafts out and unbolt the drums backing plate and bolt on the disks backing plate and slide your shafts back in. Atleast that is the way it used to work... I can't imagine they changed anything.
My thoughts as well.
johnsonwillie199
