Where to get constant power with ignition off For 2018 tahoe
Jorge1313
can you share suggestion of where to get constant power out fuse box I don’t wanna taps into a wire or cut one off or snip it . I thought of fuse box to hardwire a gps. Some many fuse box any idea which is the easy way also need a ground too . Is a plug in fuse adapter a good idea those fuse that a have a wire all ready all you do is put it in a fuse box. What your suggestion. New to this need all the help I can get . Thanks all
iLikeEggs
Potato!
Oregon, USA
There's a secondary fuse panel at the end of the dashboard by the drivers door. You can probably find a live one to tap into. Or, run a wire from the battery through the firewall. There's plenty of places to sneak one through.
cmatt
One of the factory locations used for constant +12V is the X61A junction block located in the driver footwell next to the brake pedal. That’s where upfitters grab the circuits for radio, lights, siren controls, etc.
Drewphil
