Tahoe/Yukon Headlight Information Thread
05Single
afraid of the dark
Alright guys, I did the DRL delete by replacing the DRL socket with another turn signal socket and used LED switchbacks. My drivers side won't flash with the turn signal, but the passenger side is good. The drivers side will flash with the hazards though....rewired that side in case I had a bad solder joint and still nothing...any ideas?
If that side worked before it’s either 2 things , your wiring or fuse. Also make sure leds are or are not polarity specific. Or swap bulbs left to right too.
I guess that’s 4 things
Ambitious02
Southern Cali
@05Single Haha yep, but I'll double check all 4!! I didn't check fuse since all flashers on the truck work aside from that one. When I hit the turn signal they do a very slow fade from white to amber but just stay solid amber and don't blink. It's like they try to pulse, but don't actually flash. But when I hit the hazards they flash amber as they should. Could it possibly be the socket itself? I will check fuse and swap around the bulbs to see what I get and let you know. Thanks Bro!!
Ambitious02
Southern Cali
@05Single Well I trouble shot it to no avail!! I put the stock bulb back in both sockets and they worked as they should...so only thing I can think is the Led Swithcbacks are faulty or it has something to do with the Led tailight's... I noticed the driver's side was slower on the turn signal in the rear with the LED's installed in the front verses the stock bulbs. At a loss on this one!!:banghead: Maybe a relay or something is necessary because again the hazards work flawlessly!!:nono:
BG1988
My answer is always remove any trace of amber. It won’t ruin the housing, it will just be missing it. Just depends on what the owner likes. I will say this tho, not having an amber reflector is illegal in all 50 states, same with not having a side marker. But I’ve never been harassed for it in 20 years of amberless driving. Every vehicle Ive ever owner I removed the amber. But I’ve never lived in states with those strict vehicle yearly inspections.
you can just put a temporary one...
05Single
afraid of the dark
You have resistors ? You have fuse for flashers, and separate fuses for right and left signals
Ambitious02
Southern Cali
Naw bro, no resistor's! I will go and check all fuses though. Stuff has been crazy at work so she got put on hold for a bit. Should have some time this week to get back on it tho! Thanks Bro!!
mbp1979
North Little Rock
Look good . Those matchbox’s in the highs ? I was too lazy to take the lenses off mine lol. Are you finished with the signal housings ?
Its so easy to remove the lenses you should try the 2015 up model headlights those are ridiculous because of the permaseal. I used matchbox's in the highs id wish I would have put another set of h1's in there but I didn't think they would fit but im almost positive they will but would take alot more work. I should have my signals done in the next couple days sealed them back up but going to go around again and put a good thick layer around the inside. If everyone knew how little is holding them together. The first thing everyone should do is get a tube of gasket maker and go around each lense so the dont leak brand new out the box.
05Single
afraid of the dark
If I were to remove the lens I was gonna put a led hi-lens in the high beam spot
05Single
afraid of the dark
I got a set of those but the light pattern is way to small for my liking. Its very tight.
It is but combined with the high beam of the H1 I feel like it would cover a lot of ground . Too bad the MLED is so huge . I mean anything would fit with hours of trimming lol
mbp1979
North Little Rock
Yep ur right I wondering if a morimoto mini d2s would fit in the low beam side Im thinking i may try and put the mini h1 on the high beam side. I bet if that would fit it would look amazing.
Sent from my SM-N960U using Tapatalk
05Single
afraid of the dark
It would if you got the skill and time. I know I don’t have the patients lol. And I’m happy with my 7.0s. Anything more would be overkill for my preference. I don’t even like light bars. I am probably going to switch to 8.0s this coming Black Friday, heard it’s a noticeably brighter and wider beam compared to the 7.0
05Single
afraid of the dark
I did add a red passive demon eye for my morimotos . With the previous acmes I had used dark blue to match the body paint and it wasn’t visible at all. Anyway I’m happy how these turned out.
Dh1280
