Tahoe/Yukon Headlight Information Thread
mbp1979
North Little Rock
Look good . Those matchbox’s in the highs ? I was too lazy to take the lenses off mine lol. Are you finished with the signal housings ?
Its so easy to remove the lenses you should try the 2015 up model headlights those are ridiculous because of the permaseal. I used matchbox's in the highs id wish I would have put another set of h1's in there but I didn't think they would fit but im almost positive they will but would take alot more work. I should have my signals done in the next couple days sealed them back up but going to go around again and put a good thick layer around the inside. If everyone knew how little is holding them together. The first thing everyone should do is get a tube of gasket maker and go around each lense so the dont leak brand new out the box.
05Single
afraid of the dark
If I were to remove the lens I was gonna put a led hi-lens in the high beam spot AEC63626-E3FE-4173-B1B3-3F2486D36387.jpeg
05Single
afraid of the dark
I got a set of those but the light pattern is way to small for my liking. Its very tight.
It is but combined with the high beam of the H1 I feel like it would cover a lot of ground . Too bad the MLED is so huge . I mean anything would fit with hours of trimming lol
mbp1979
North Little Rock
Yep ur right I wondering if a morimoto mini d2s would fit in the low beam side Im thinking i may try and put the mini h1 on the high beam side. I bet if that would fit it would look amazing.
05Single
afraid of the dark
It would if you got the skill and time. I know I don’t have the patients lol. And I’m happy with my 7.0s. Anything more would be overkill for my preference. I don’t even like light bars. I am probably going to switch to 8.0s this coming Black Friday, heard it’s a noticeably brighter and wider beam compared to the 7.0
05Single
afraid of the dark
I did add a red passive demon eye for my morimotos . With the previous acmes I had used dark blue to match the body paint and it wasn’t visible at all. Anyway I’m happy how these turned out. 4F99C9C7-48DB-427C-B847-8C0AE8F1A5F8.jpegC2210301-5ACF-4CC6-B249-37350165A8B5.jpeg53672864-5D45-4A47-9134-61AD0AA0BB3C.jpeg8928C9E5-24BB-4DC9-859A-F0441D1D2354.jpeg977E6409-B17D-457D-A1DA-8B698C25E071.jpeg
mitchievu
