Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
As far as I'm aware the 07+ does not have an in-cabin air filter. However my wife's 2002 Ford Escape (a car that was $40,000 less new) does have one... happy breathing!
Go over to the performance section and look for the how-to install thread on this. Looks real easy and it is located on the passenger side just above the passenger feet. They stoped making our hoes and yukons with this cabin filters in 03.
located under the glove box, there are two in there. I changed mine and thought I got an extra one, then i looked closer. takes about 10 mins to change.
I have a rectangle metal box with door on it about the size of one of these filters. It goes vertical, but I got a wire harness in the way of the door on it. It looks like it would open from the bottom. Its below the glove box, behind it sorta to the left of the black cover panel under the dash. Is this it?
My car is a 2000 and was built in 11-1999. The thing I saw is parallel to the dash. Just behind the glove box is a amp looking thing and it maybe one and the same I see at the bottom that has a plug wire coming from it on one side. I do not not think this is it. My manual shows it being vertical and its parallel with the side door close to the kick panel under the dash close to the end of the dash by the passenger door. I do not see anything there. So did I get a vehicle without one? My manuel says its under instrument panel but picture looks like the side of the dash on passenger side. I looked under driver side and did not see anything there either. It is suppose to have a black plastic clip over it looks like in picture in manuel. It just shows the filter coming out below the glove box and thats it. Manuel also stated if its equiped with one thats were it is. Can someone take pictures and post on here so I am correct in my thinking that I don't have one possible or its inside that black cover with two bolts thats apart of the ac vent work thats below the glove box?
Kind of hard to see but there is one clip in front and one screw in the back that holds the cover on. Take the screw out and it will drop out. Remember, there are two filters in there. I ordered the FRAM Freshbreeze off of Amazon the other day, cheaper than auto parts stores. They come 2 in a box... Just did it last night!
Mine does not look like that unless its onder the black cover that goes almost down to the floor board. Got any pics looking up some under there? Pic of that are and the upper dash part? Did you take a black cover off to get to that section under the dash? What year is your vehicle?
Yes, you have to take the black cover off. 3 screws, one under the center-dash area, which is a P.I.A. Sorry, don't have any more pictures of this area. Once you take the cover off, you will see it. It will be to the left of your blower motor resistor.
Yes, I know I am quite the idiot and can't believe it took me this long to replace my cabin air filter. My 01 Yukon has been filtering all the crap Los Angeles and Tahoe can offer and man was it a sight pulling both the filters our. Insane and I can't believe I along with my company have been sucking that air in.
Thanks for the posts and helping me clean this out!
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
