Really enjoying this new Denali XL
MrMike48
After I bought my 2010 Denali in 2015 I ask the dealer service department if they could provide me with the original build sheet and they were happy to print it out and mail it to me. I shows both the codes and descriptions.
a tech2 will tell you exactly what is causing the error, mine was a loose connector on a front shock, never would have guessed, felt like it was tight to until I pulled on it and it came right off, the little metal clip wasn't attached properly, I had had the front shocks replaced 2-3 months earlier so it took some time to decide to throw a code, the tech2 led me right to it, "front right sensor intermittent"
Which Tech 2 Unit should I buy? I also have a 2017 Camaro SS with Magnetic Ride.
the tech2 won't work with the 2017, that requires a more modern scanner that run $1200 and up even for the clones and yearly subscriptions
otherwise there is only one tech2, or emulators that require a laptop or tablet or pc
as far as the gds2 portion of what james mentioned I haven't got that far yet, waiting on a tablet to arrive first.
avalonandl
avalonandl
Troy, MICH & Naples, FL
So I think the air compressor is dead. Fairly common. Arnott shocks # 2708 are about $ 200 a piece rebuilt including a core of 50.
Where is the compressor so I can check it.
agmanw8n
