Opinions on Potential Hybrid Mods ...
THE YETI
Director of Operations
South FL
this baffles me... performance and hybrid? doesn't that sorta defeat the purpose?
soulsea
soulsea
Bar
Not really ... we do have a 6.0 under the hood ya know. :)
---------- Post added at 08:20 PM ---------- Previous post was at 08:14 PM ----------
Btw, I'm looking at the differences in engine bays between the HyHoe and Hoe:
picture.php
picture.php
Two questions:
1. What is that thing (electronic) that plugs into the tube between the two metal clamps?
2. What is that other plastic thing closer to the motor thats located in front of the pipe in the regular Hoe but is sort of on top and to the side of the pipe on the HyHoe?
:think:
THE YETI
South FL
That is the mass air sensor.
#2 is an air baffle.
soulsea
soulsea
Bar
I see thanks.
Now do either of those parts (especially the air baffle) connect to the CAI?
I'm asking because on the volant site they specify the previously linked cai for the 07+ 6.0L engine, but I don't want to get it and find out that it doesn't have the proper connections.
THE YETI
South FL
the volant will replace the entire tubing from the intake manifold to where it went into the airbox. Then it supplies you with a new tube and new airbox, so all that will go away.
Is your hybrid 07-08 or 09+? There is a difference in the gas versions of these vehicles, where the mass air meter connects to the airbox. On the 09+, its integrated into the tube and requires a different air intake, on the 07-08, its a seperate piece.
soulsea
soulsea
Bar
Mine is an 09 ... so I'm not sure what I need.
The amazon link I posted says it's compatible for my vehicle but I'm not sure I trust them. :think:
THE YETI
South FL
no, its not. 09+ had an entirely different air intake where the intake tube had the mass air meter integrated into it. You would have to section out the mass air meter and splice it in, per say, which would sorta be a pain. They do make a kit for the 09+, but im not sure who makes it, how much, and what it entails.
felixgun
Lafayette, LA
What's a K&N drop in? :think:
And the reason to do it is cause it looks better than the stock situation and apparently sounds great ... what other reasons does one need? :)
What "sounds great" is the intake tube. Not the filter.
felixgun
Lafayette, LA
Volants cai for 07-08 is cake but the 09+ is known to throw errors on DIC and a few other things that steered me away from it (aside from the extra $75-100 they tack on for that clean heat shield cover). That's why I went with the Airaid. Like dirk said, the maf sensor is in a dif spot on 09+ vehicles but who I don't know if that includes hybrid or not...
For mine I'm getting the airaid jr intake but i don't know if they make that for the hybrid or not and that's about what we are talking about here :shrug:
soulsea
soulsea
Bar
Airaid sells the intake tube separately dubbed a "Modular Intake Tube". Volant doesn't sell that separately.
Just went to their site and it's not available for the 09 6.0L ... other than a couple of filters this is what they have available:
picture.php
---------- Post added at 11:09 PM ---------- Previous post was at 11:08 PM ----------
What I don't see on their CAI or on the Volant ones is where the MAF sensor plugs in. :think:
THE YETI
South FL
picture.php
The mass air sensor isn't just a plug. It's the entire piece between the two clamps, and the engine harness plugs into it.
soulsea
soulsea
Bar
I see ... still, I don't see where the harness plugs into these CAI.
My apologies, I'm probably not getting something really obvious. :(
The maf sensor is circular and is the same circumference as the tube and the place in the 'box'. The maf should go in that spot
soulsea
soulsea
Bar
Or does the CAI attach to each end of the existing sensor?
Ie, the sensor stays and the filter and tube get attached on either side of it? :think:
dizhai
