Sammie859
This is what Goodyear gave me! They said it past a spark test But no tach signal? What’s that even mean?!
This is what Goodyear gave me! They said it past a spark test But no tach signal? What’s that even mean?!View attachment 348429
I just got it back late yesterday. So today I’m going to check the wires from the distributor. Check the ECM plug. I’m just confused! Check the connector on the ignition control module. It's mounted next to the coil. It's been YEARS, but I believe the tach wire is white. Although, I'm wondering how it would pass a "spark test" if the CMP sensor or ICM were faulty.
Do you have it back in your possession? Have you checked the points mentioned so far?
Idk what brand was used. My husband bought it a couple of months ago and doesn’t remember where! This one baffles me.. How can it have spark, but no tach. You cant have one without the other as far as I know. This has a very straight forward DIS system.
So the easiest route at this point is to replace the ICM. I believe for your truck, its part #19352931 ACDelco. This will take a average mechanic about 30 minutes to change.
While the cap is off, have someone turn the key on, and turn over the truck. This is just to verify that the cogs on the crank and distributor are still working, and spinning the distributor.
But this is not guaranteed to fix the problem. Your problems started after you replaced the Crankshaft Position Sensor. So this is still highly suspect.
What brand and part # was used for the Crankshaft Position Sensor? This has been asked a few times, and still not answered.
What @PNW VietVet said also hold a LOT of water. The wires going into/to the distributor are a KNOWN failure point for the 4.3, 5.0, and 5.7.
Im Not completely sure what they did, according to the report, not much. They said they tried to swap the relay (nothing changed) and they tested for spark and it passed. But they didn’t say where they tested for spark or would that matter?I would hope that Goodyear would have verified that your Top Dead Center Mark, and your Rotor in your distributor were properly aligned, and that your plug wires were all correct before doing the “Spark Test”. I am baffled why they would not replace the Cam Position Sensor to clear your P0340 code. I feel that a no Tach Signal (RPM needle not moving on the dash) could be from one of these sensors not sending its signal. Going to a GM dealer may give you piece of mind that their Techs have the experience on these vehicles at this point.
The check gauge light is what threw me off. I’d never seen it on before.With it not running, those are completely normal..
I did check #5 and #7 today and they are correct.You mention changing the plug wires. Have you verified the cap to plug order is correct? I am sure you did but this was one thing changed right before the issue appeared.
Verify and eliminate the most obvious and easiest things first.
What do I do? Check the pins with the tester?Buy a spark tester Sammie 859! You can do it!
Tach operates off Terminal "D" of Ignition control module thru Ignition coil Term"C" White/black wire exiting coil on Term"B" to tach input.
PCM connector C1(blue) pin 8 cam sensor ground, pin 3 cam sensor signal(X1).
So possibly an ICM connector issue.
I’m not sure when or if it’s been replaced. I’ve had it for a year!When was the FUEL PUMP last replaced ?
