2021 Tahoe won’t start
Ridaz80
I have a 2021 Chevy Tahoe recently it gave me a PO615 code which say it’s the starter relay so I checked it and was good so I changed the starter and still won’t start any advice is appreciated.
blanchard7684
Senior Member
Edit: po615 is a starter relay circuit malfunction.
So you are not getting any cranking.
Check for power at the starter with a test light or volt meter.
If no power then you need to check or replace the relay.
I would also check the battery with load tester.
Fless
Moderator
People's Republic of Colorado
Define "won't start." Does the engine crank (turn over) but not actually fire? Or is this a no-crank?
P0615 indicates a Starter Relay Control Circuit problem. Either a short to ground or high resistance or an open in the circuit.
What tests were done to verify that the relay was good, and that the circuits to and from the relay were good?
If you bypass the starter relay (see YouTube for procedure) will the starter engage and turn the engine over?
Ridaz80
Ridaz80
The engine won’t crank over I tested the relay with a relay buddy and shows that it’s good I also bought a new starter and installed it when I go to turn it on the dashboard lights up and says start engine I put the button and nothing happens no crank just instructed to roll up and down left and right window
blanchard7684
Senior Member
Seems like the bcm is going into relearn mode like a battery was replaced or losing power.
Check the battery cables for bad connection and test the battery.
Ridaz80
Ridaz80
I removed the starter relay and I jumped it I hear the starter turn but the engine doesn’t turn over the starter just sounds like its spinning
blanchard7684
Senior Member
Try turning the motor via front crank bolt to see if it is locked up
2024 White Tahoe
Which engine?
justinakay79
