Gas pedal start/stalling
bacongurl10
My 97 chevy tahoe has stalled when coming to stop. Starts cold perfectly. But once hot dosent want to start. Pressing the gas pedal down can get it to start, idles rough. I have replace the crankshaft sensor, iac sensor, throttle position sensor. Have test fuel pressure and thats fine. Any ideas?
Eman85
Check engine light work? Is it on at any time? Any stored codes? Can you read data? If you want to keep firing the parts cannon try the coolant temp sensor.
Welcome to the Forum from NH.
Pics of the truck, please.
I cannot personally assist you with your issue, but other members of this Forum much more knowledgeable than me in this area will chime in.
exp500
Start with distributor cap and rotor. United DCR -820X or Delco /Delphi only. NGK or AC plugs. Fuel filter.
Question- What was Fuel Pressure and how was it tested?
I like using FP Gauge on 6 foot hose so I can read on test drive Scaning live data at same time.
BadDaddy2003
