Headlight Burning
Sam Harris
Texas
I believe that the LED lights have less resistance than a halogen, I think the
That's true, it's weird. It was flashing normally until the headlights were installed though.
Which leads
Me to believe you have some interesting wiring going on up there..
JPVortex
JPVortex
Connecticut
Which leads
Probably tbh. I also just remembered the light right next to the turn signal bulb is also led, and I wonder if that would have anything to do with it?
Sam Harris
Texas
That would be either the DRL, or the little 194 IIRC, marker light. The marker could affect hyper flash, as on most, if not all GMT800’s, the turns alternate between the marker and turn bulbs. But I’m not positive. And, again, this SHOULD have zero to do with your headlights.
JPVortex
JPVortex
Connecticut
Yeah I'll try putting halogen marker bulbs in. Its not my DRL because I have the fuse for those disconnected because I dont like the way they look.
MassHoe04
Western MA
Headlight bulb socket connectors on the ends of the harness have been know to get fried due to age and bulbs with wattage ratings higher than designed. Replacement sockets are available and pretty cheap.
Do yours look browned or cooked?
I have a mish-mash on my 04. PO installed LED corner lights. I have regular turn signal bulbs and halogen headlamp bulbs on Hi/Lo beams.
I put LED into the DRL, because the sockets were toasted a little and the bulbs would not last more than a few weeks.
I have no hyper-flash or flickering with this 50/50 combo of LED and regular bulbs in different places. The PO may have added resistors to make the corner lights work. But everything is playing nice with each other.
My turn signals do alternate flashes between the regular turn signal bulbs and the LED amber corner marker lights. I like that feature. It makes for good visibility at all angles when I signal to turn.
this is why I always tell people that go to HID to use relays, if you use thicker gauge wire and relays direct to the battery and ground to the frame then there is basically zero load on the factory headlight harness because all it is used for is a trigger signal. I started running HID's way back like 20 years ago, it didn't take long to figure out that it will burn stuff up. The HID stuff out there now can range from complete garbage to high quality. As time has gone on they started making them cheaper and with very low quality parts so much that you would be lucky if they even turn on out of the box. Ballast matter lol
They didnt come with a transformer, it's just light
Interesting... I don't believe that I've ever seen an LED headlight that did not come with a transformer between the LED light itself and the truck's headlight harness (of course, I have not seen them all).
andyd
Yes, if you use them in the turn signals.
But you specifically said you were changing the HEADLIGHTS, which have NOTHING to do with how the turn signals flash. Or learn me sumpin new.
I also did the confused puppy dog look. lol Until I looked up the harness. It looks as if multiple items take the power and ground on the same circuit. So it maybe possible ? I attached the harness photo. 2005 tahoe.jpg
I also did the confused puppy dog look. lol Until I looked up the harness. It looks as if multiple items take the power and ground on the same circuit. So it maybe possible ? I attached the harness photo. View attachment 393240
pretty sure that pictured harness is for a 07-14
BWASTEEZE
