Engine ticky-ticky-ticky sound at idle (2007 Tahoe 5.3L, 135,000 miles)
mjreynolds928
mjreynolds928
Clayton NC
I want to see the cracks need a picture . And check exhaust manifold bolts Im sure you have a couple bolts missing . Yes take finger and turn on cold engine the exhaust manifold bolts they might come out when you try to turn them . If it was a cracked flex plate it would of broke a long time ago .. only guessing.
Sent from my LGL84VL using Tapatalk
this is only angle of the flex plate. I tried to turn the flex plate and kept missing. Is shows one crack. The first time I looked through the hole I saw two.
mjreynolds928
mjreynolds928
Clayton NC
You said you saw two cracks at flex plate. How did you identify that, used a camera snake up to the flywheel bolt area?
Check out the picture I added in this thread. It’s from a different angle but you can see one crack. The first time I saw the cracks, their was two. I can’t imagine how much is actually holding on to this flex plate.
Sam Harris
Texas
Yikes!
Larryjb
I see that the torque converter comes out with the transmission after unbolting it from the flywheel. Then, the flex plate can be removed to gain access to the rear main seal.
However, this may not give enough room to work to get tools in there to get at the seal.
mjreynolds928
mjreynolds928
Clayton NC
I just came across these two videos:
and
They're painful and funny to watch, but also will give you an idea what you might be in for if you try it yourself. This would be one of those projects that could probably be done in a day if you know what you are doing. If you don't, it shows you what you are in for.
So I watched these videos and it was rather painful... I am wondering if I can unbolt the transmission and slide it back about 2” and replace the flex plate in stead of completely removing the tranny and transfer case???
Dustpan
