FAUST
2007 Tahoe 5.3L Flex Fuel - some hesitation when accelerating. Periodically throws p0300 - indicates lifter replacement as fix.
There isn’t a loud tick typically associated with collapsed lifters. Talking with a GM master tech, suggested testing fuel pressure before performing lifter DOD AFM delete.
Testing fuel pressure - 59-60 PSI while running - when relief valve is open drops below 30 and doesn’t recover.
Testing with key on engine off - 59-60 PSI. After 25 minutes pressure drops to 35 PSI and continues to drop.
My question is - what is an acceptable loss of pressure over time? Would this be an indication of a bad fuel pump?
Any ideas or advice is great!
Pictures showing PSI before and after relief valve is open - engine is running.
Geotrash
Dave
Richmond, VA
How many miles on it? In my opinion, that's an indicator of a failing fuel pressure regulator which is part of the pump assembly in the tank. Your pressure should be a steady 43 psi or so. I had the same thing happen in my 2007 at around 200K miles. Replacing the pump fixed the problem.
ya that's high pressure when running, it should drop to 43-45 or so while running. (hybrids may be different)
may or may not be the cause of your random misfire though, not sure why someone would immediately jump to "lifters" because of a random misfire.
plugs, wires, coils, injectors, leaks, wiring, etc should be checked before jumping to anything else
steiny93
this thread had a reply with some time to pressure lose intel: https://www.tahoeyukonforum.com/threads/2008-5-3-ff-hard-starting-issue.130199/
on the 2008 I have tracks on; it had a fuel pump issue last winter; it would get to 60psi at startup then run in the low 40's; it would lose pressure very slowly
I'd recommend going through the troubleshooting procedure to see if its the pump/regulator or injector(s)
FAUST
FAUST
There is about 150k miles.
FAUST
FAUST
Plugs, wires are new. Basic test on coils (swapped non misfiring to potential misfiring cylinder) - no change. Oh, I’m using a BlueDriver basic scan tool that shows misfiring and which cylinder.
I should say - the original scan from autozone said lifter - that’s why I’m still testing and researching, seemed a bit extreme.
Next is on to injectors - I have done 2 seafoam treatments over the last year and that has not helped.
Any mor ideas to diagnose is welcomed!
FAUST
FAUST
Awesome! Thank you for this! I’ll get after it and let y’all know what I find.
Geotrash
Dave
Richmond, VA
As I said above, I'll wager $100 that the problem is the pressure regulator in the fuel pump. When mine went, I got the same occasional P0300 and similar pressure readings.
Here is the diagnostic procedure to be sure. You will need a Tech2 or equivalent to perform the diagnostics. They are available for $250 or so from chinacardiags.com.
Circuit/System Testing
Note:
  • The fuel pump may need to be commanded ON a few times in order to obtain the highest possible fuel pressure.
  • DO NOT start the engine.
  1. Ignition ON, engine OFF, command the FPCM Fuel Pump ON with a scan tool and observe the fuel pressure gauge while the fuel pump is operating. Verify the fuel pressure is between 345-690 kPa (50-100 psi).
¤If the fuel pressure is greater than the specified range, replace the fuel tank fuel pump module.
¤If the fuel pressure is less than the specified range, test, inspect, and repair the items listed below. If all items test normal, replace the fuel tank fuel pump module.
  • Restricted fuel feed pipe
  • Inspect the harness connectors and the ground circuits of the fuel pump for poor connections.
  1. After the fuel pump is turned OFF, verify the fuel pressure stabilizes between 500-599 kPa (72-87 psi).
¤If greater than the specified range, replace the fuel tank fuel pump module.
  1. After the fuel pump is turned OFF, verify the fuel pressure does not decrease more than 34 kPa (5 psi) in 1 minute.
¤If the pressure decreases more than the specified value, perform the following procedure:
  1. Ignition OFF, relieve the fuel pressure. Refer to Fuel Pressure Relief (CH-48027) See: Fuel Pressure Release\Service and Repair\Fuel Pressure Relief (CH-48027)Fuel Pressure Relief (Without CH-48027) See: Fuel Pressure Release\Service and Repair\Fuel Pressure Relief (Without CH-48027).
  2. Install the J 37287 between the fuel feed pipe and the fuel rail.
  3. Open the valve on the J 37287 .
  4. Ignition ON, command the FPCM Fuel Pump ON with a scan tool and bleed the air from the CH-48027 .
  5. Command the FPCM Fuel Pump ON and then OFF with a scan tool.
  6. Close the valve on the J 37287 .
  7. Monitor the fuel pressure for 1 minute.
¤If the fuel pressure decreases more than 34 kPa (5 psi) within the specified time, locate and replace the leaking fuel injector(s).
¤If the fuel pressure does not decrease more than 34 kPa (5 psi) within the specified time, replace the fuel tank fuel pump module.
  1. Relieve the fuel pressure to 69 kPa (10 psi). Verify that the fuel pressure does not decrease more than 14 kPa (2 psi) in 5 minutes.
¤If the fuel pressure decreases more than the specified value, replace the fuel tank fuel pump module.
  1. Operate the vehicle within the conditions of the customer's concern while monitoring the fuel pressure with the CH-48027 . The fuel pressure should not drop off during acceleration, cruise or hard cornering.
¤If the fuel pressure drops off, test, inspect, and repair the items listed below. If all items test normal, replace the fuel tank fuel pump module.
  1. If the fuel system tests normal, refer to Symptoms - Engine Controls
FAUST
FAUST
This is quite the process. I’ll start here and see what happens. The challenge is buying a new scan tool at the moment.
Thank you for the help on this. I’ll reply once I’ve been able to run the diagnostic.
2007s do not have a Fuel Pump Control Module. The pump is controlled by the ECM and a relay like in the previous generation and pressure cannot be seen with a scan tool.
Key on (might have to do this several times to get highest pressure), pressure is to be between 50-60 psi and not drop more than 5 psi after one minute.
Here is a description of how the 2007s pump works:
FAUST
FAUST
Thank you! I listed a test outcome earlier - PSI went from 59 to 35 over 25 minutes - it was a steady drop, about 1PSI PER minute.
I’ll try again and get an average of multiple tries to be sure there is a consistency of pressure bleed.
I’ll post it later today or tomorrow.
Geotrash
Dave
Richmond, VA
That's a good catch, James. The info I sent came from the 2012 troubleshooting guide. Thank you.
FAUST
FAUST
Yes - thank you, James.
Thank you, Dave - for the troubleshooting guide regardless. I appreciate the effort and shared experience throughout. It’s nice to know knowledge coming my way is multi-faceted - personal/professional experience and specific technical workflow guides!
Many thanks.
Thanks, I learned the hard way when a member on here and I met up to diagnose his fuel and evap system. Totally perplexing until we discovered that they ran the old way with a relay and no FPCM.
FAUST
FAUST
Dang! I’ll say it was worth it, given my current situation haha
Thanks again!
petethepug
Michael
SoCal
This is good info. Anyone know if the f/p in both the 07 & 08 operate the same way?
09 is when GM changed the f/p design from a three hose to a two hose version. I assume anything prior to 09 would operate and diagnose the same way.
As far as I know it was just 2007. I do not recall whether or not the 6.2s are wired up this way, the 4.3s, 4.8s and 5.3s are for 2007.
FAUST
FAUST
Psi started at 55 with key on engine off. After one minute PSI was 51 key off and 54 key on.
FAUST
FAUST
What would be the natural next step in diagnosis? I haven’t tested anything else and I wanna spend the time vs. throwing money at it.
Thanks for all the help to this point!
TexasTaz
