mjreynolds928
I want to see the cracks need a picture . And check exhaust manifold bolts Im sure you have a couple bolts missing . Yes take finger and turn on cold engine the exhaust manifold bolts they might come out when you try to turn them . If it was a cracked flex plate it would of broke a long time ago .. only guessing.
Sent from my LGL84VL using Tapatalk
this is only angle of the flex plate. I tried to turn the flex plate and kept missing. Is shows one crack. The first time I looked through the hole I saw two.
![B2F26A30-EA4B-4997-84AF-9AB1DC5437DB.jpeg B2F26A30-EA4B-4997-84AF-9AB1DC5437DB.jpeg](https://www.tahoeyukonforum.com/data/attachments/233/233613-760a91f28f944146a7fe1c8e57b0258a.jpg)
