6.2 swap thread
Noticed my hot oil pressure does get pretty low. 25ish at idle. I am just using basic oil for now gonna change it a few times before putting synthetic in.
It pumps up immediately when hitting throttle but seems to cap at 50psi or so. Wonder if its the relief valve
The valve in the oil pan is supposed to pop off around 50-55. I don't know about the relief in the pump, and that depends on the spring used.
L
ls1frc
Im not worried about it, engine is as quiet as a mouse (for a cammed LS motor).
What is a little strange is the cam chops like it has positive overlap. Its -9, I was expecting more of a stock like idle. I wonder if the +7 advance makes it chop harder. I'll see if I can smooth that out.
Tomorrow is dry, so I will hook the wideband in and do some WOT tuning.
L
ls1frc
Installed my catch can today. Came out Clean!
1BADI5
DMV
I need to get the bung for my wideband burned in. I already have the gauge installed
L
ls1frc
Did some WOT tuning. Didn't have much time, so just roughed it in. I was lean by about 10%, got that dialed back so it's safe. Did a little part throttle tuning as well, trying to raise spark in cruise areas to improve MPG. My DFCO doesn't enable at all, so I will need to play with that too to improve MPG.
Idle needs a lot of work coming to a stop, but its gonna be a winter wonderland here over the next week or more. I'll revisit once the snow is gone lol.
One thing that is terrifyingly bad about these truck tunes is the flex fuel is VIRTUAL. It will switch your stoich point around if it thinks the fuel composition is different. Very dangerous setting! I hope all you guys with tunes have this turned off or you're really risking a bad lean condition. Either turn it off or put a real sensor in.
I tried to take a video of 1st->2nd from a roll, starting in manual mode. I hammered 1st and my phone flew out of my hand and flew into the 3rd row seat LOL.
Sam Harris
Texas
Awesome progress! We still want to see that video! Even better! Lol.
L
ls1frc
To me--that makes all the headaches worth it!! HELL YEAH!
Aside from my hood debacle, everything went pretty smooth. Its quiet, has no leaks, is running right. Came together nicely.
Its def over 100 ft lbs more than the 5.3 at below 4k. The 5.3 with the ported heads and cam was comparable 5k and up.
I need to work on MPG though its real bad lol. Hoping DFCO helps the city mpg. Highway not much I can do there.
PatDTN
Did you pour any ATF into your new torque converter before you installed it?
L
ls1frc
It shipped with fluid in it already so I just put it in. I did have to top off my trans.
L
ls1frc
Bought an iat and breakout harness. Iat in maf gets too saturated and hot restarts are terrible because it throws fueling off so much.
Foggy
KS
Ok had a few mins and found a quick spot before I had to go home to do a test....
ZL1 stall lets you go to about 2200-2300
I was wondering about the ZL1 stall converter.. I looked at way too many this spring. Decided to go with an 1800 stall converter. Built from GM core, with a lot bigger lock up clutch lining... It's really not any "looser" than the stock (1600 rpm).. So if I ever get time, I might have it restalled to 2000 ish. I think that would be better for accel..
L
ls1frc
The zl1 is a factory twin disk stall designed to hold mega HP and only costs 400 bucks. Was an easy decision for me.
brice715
