6.2 swap thread
L
ls1frc
Thank you Mike! It's funny you mention that because I thought about the starter, but I bought a Mr Gasket one that did not have the proper connections. I will return it and buy one for the 6.2. 148k on the starter, time for it to be swapped anyway.
L
ls1frc
Also noticed my trans dipstick doesn't lock in the tube anymore
Geotrash
Dave
Richmond, VA
I’ve had good luck with rebuilt and reman starters over the years. I like that one is sold by AC Delco also.
L
ls1frc
Yeah i got it from the ac delco part finder. Says its for denali 6.2
kbuskill
NE. FL.
Just make sure it's for a 6.0 or 6.2.
Out of curiosity, are they physically the same size and the one for the 6.2 just has more windings to make it more powerful or are they different sizes?
What I'm getting at is, will the 6.2 starter bolt up to a 5.3 without issue?
I am guessing so, since he put his 5.3 starter on his 6.2.
PatDTN
Aaaaaaaaarrrrgh. It never occurred to me that there was a different starter. I reused my 220k mile 5.3 starter and have noticed it sounds sluggish. Crap that little dandy is hard to get out and in!
L
ls1frc
Was just thinking with headers off its super easy. Now my headers are on I bet itll be hard and I used a non reusable remflex gasket.
PatDTN
Access to the wires and stuff through the right wheelwell.
L
ls1frc
Noticed my hot oil pressure does get pretty low. 25ish at idle. I am just using basic oil for now gonna change it a few times before putting synthetic in.
It pumps up immediately when hitting throttle but seems to cap at 50psi or so. Wonder if its the relief valve
1BADI5
DMV
Congrats man on the successful swap! No better feeling then seeing it all come together and run!
ON that note, what would you be looking to get for those PRC heads?
L
ls1frc
Thank you. Not sure on the heads, they're $1600 new and I am open to offers.
1BADI5
DMV
Where are you located? I don't want to low ball you, but know shipping cost can be a *****.
L
ls1frc
Played with the VVT today doing some part throttle tuning.
With the stock advance DIC showed about 9.7 MPG. Was able to get it back up to 12.1 by retarding the cam. Looks like it only maxes out at about 8 degrees though. I thought I could get 11, but I guess the limiter is a little aggressive.
It's definitely worse mileage than the 5.3, but that could also be from the CTSV converter.
I am going to modify the shifts too so it shifts earlier, the 6.2 doesn't need to be revved out at all to get moving. Its amazing.
The Whip
