yep auto parts is BIG business, so that means money
these factorys over in the "east" can retool in like 72 hours, to make pretty much anything.
that is scary, if they desired to make war we will be on the loosing end at first anyway until we can catch up.
they are already baking and poping out stuff left & right along with Belt & Road, Africa will be the new China... mark my words
j91z28d1
America goes where the cheap labor goes and when it's no longer cheap, we go some place else. so nothing would supised me about where it goes next. it just depends on the govt if they take advantage of what's learned and left behind or not. Mexico would have already out Chinaed china by now if the cartels didn't run the place keeping labor costs low ish still.
Yanking everything out is no small task the way everything is held together with crappy plastic clips these days.
You're bound to break a few tabs in the process.
true, and after some years things get brittle and break easily. If you take your time and not rush it then it generally works out
if you go into it trying to go as fast as you can then you run into breaking clips and yanking wires out even by accident.
sometimes the retainers will break anyway and you just have to take it in stride
Texas_Made
