2012 Rear Escalade Bumper With Dual Tips - Part numbers
dnme305
I have magna flow exhaust on my truck would I have to swap that out? I don't mind eliminating the spare tire.
THE YETI
Director of Operations
South FL
No. Just need to run a y-pipe and lose your magnaflow tip.
dnme305
thanks is your shop in Weston, FL?
---------- Post added at 10:28 PM ---------- Previous post was at 10:26 PM ----------
Nvmnd yes it is... Im prob 10 min from the shop..do you guys install as well as exhaust work?
THE YETI
South FL
I can personally do it, sure. But the exhaust work a shop would do.
spotted_giraffe
I just read over this thread quickly at work, so I may have missed it. It might also be a stupid question. Will this work on a 2010 EXT?
Ben
PCB, FL
Sorry I must of been drunk/. I know it doesnt work lol.
madmanhiker
Jacksonville, Fl
quick question on this....... at least for my denali (2014), it states that I would have to remove the spare tire. I don't want to ride without one, that being said, what do other folks do? is there a vertical spare tire mount ability inside the cargo area instead of it just lying flat like a sack of potatoes? Plus, we had to remove the 3rd row because we needed more cargo room for deliveries and groceries. thanks for any advice.
madmanhiker
Jacksonville, Fl
Oem tire repair kit is what the esky with this bumper comes with I think.
thanks. I see this is a pesky issue even with esky owners. I just had my duals done and I had to run my pipes on one side (because I didn't want to lose the spare.) That being said, I don't like the way it looks, but... if I change the rear to esky duals, I lose my spare regardless. arrgh
http://www.cadillacforums.com/forums/cadillac-escalade-ext-esv-forum-2007/270094-2013-escalade-esv-dual-exhaust-full.html
NathanJax
NathanJax
Vacation Nathan
Jax, Fl
VVV this VVV
You can go custom and do an electric hoist (and hope it works when you need it) or people have kept the spare tire, made a hole in the bumper and done a crazy re-route of the exhaust.
KennyK
Well someone ran into the back of my wife's yukon
So it looks like I will be taking on the challenge of doing this with retaining the spare tire by fabing up my own exhaust and heat shields
THE YETI
South FL
That's not the problem. The problem is the hoist system for the spare and how you're going to access it.
You're better off just installing the tips only into your factory bumper and calling it a day. Cheaper and you'll achieve the same look.
KennyK
I plan on rotating the hoist so that the access hole is behind the hitch cover
I need a new bumper anyway mine is messed up from the wreck
THE YETI
South FL
Make a new thread too! Would like to see the build. :D
j_jerry79
