Cooling fan circuit on 6.2L
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Thanks for the tips on sourcing wire!
Anybody have the PN / Connector End view for the GMT900 fan connectors?
The plan is to, rebuild the fan harness 8 gauge wire... Or 10 if driven by connector limitations, more in a sec.
I'm getting ready to order the pins for the fan connectors. I don't have access to the FSM for the GMT900 though. I've found the terminal pins and wire gaskets for the GMT800 on Mouser.com However, they're spec'd to accommodate 12 to 14 gauge wire (GMT800 harness uses a 13 gauge). NOT the 8 to 10 gauge I need to run.
If I had the aptiv part number (shown below) from the "connector end views" in FSM for GMT900 I could order the terminals for larger gauge wire. The GMT900 uses 10 gauge in the fan harness.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Del City and Waytek are my sources for stuff like wiring and associated stuff like terminals, connectors, tools, etc.
Dang these sites are GREAT especially Waytek. Only thing looks like order minimums are 100ft on most wire. My plan is to build a drop in harness upgrade with factory fitment. If I'm able to accomplish that then I may order from them and build these harnesses for my friends.
ebay has gxl wire..
search popped up delcity.net
Ordered mostly from eBay as I can typically get in smaller lengths. I'll probably just order there for my prototype.
Thanks!
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
This one?
You're awesome! This website is another great resource. Thanks! Mouser is out of stock, I put an order into them. If they had them they'd be a fraction that cost.
Just seconds ago I ordered 8 gauge GXL wire to see if SOMEHOW that terminal will accept a TOUCH bigger than 9 gauge wire (it's spec'd max). 8 gauge would be ideal IMO, although probably not necessary, as current per wire will be half what it was on the feed line which is 8 gauge. Which writing this, perhaps it wouldn't hurt to up the feed line to 6 gauge, it does heat up. I'd wanted to get the Black, Yellow, Gray, and light blue to match the factory but that would have cost several hundred dollars so just got a 25' of black and 25' red for now.
Now I put in order at your link / custom connectors to get the remaining parts.
I'm quickly getting a fair amount of money tied up in this... :p
LsHart
Senior Member
I've seen those. I'm trying to keep an as factory configuration as possible. However, maybe worth canibalizing one of those for the wire... Otherwise my next question was... where can somebody get 8 or 10 gauge bulk GLX J1128 compliant wire or otherwise for under hood conditions?
Yes, we sell it a Forklifts ETC. up in the good ole Memphis. We have a website and will ship it. We make hydraulic hoses too!
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Oh cool. What's your website?
I ordered just whatever colors on eBay but really need to order correct colors to maintain factory wiring diagram if I build harness kits.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
AI lead me down a rabbit hole insisting there's a recall of sorts on GMT800 / GMT900 fan relays due to melting issue. After much searching I found no evidence of this being the case. *sigh* Did find some interesting info though...
Quite a few people did melt their fan circuit doing eFan upgrades. One person speculates older motors draw more current... Could quite possibly be the case. I also drive off road a LOT. Possibly mine got caked with dust.
Interesting chart I found elsewhere.
mikez71
Neat chart!
AI has led me down a rabbit hole too..
It's a know-it-all, that doesn't know when to say it doesn't know...
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Neat chart!
After a hour of trying to find AI's phantom TSB I got a chart lol
Not speculation. Fan motors that work well, so long as they do, won't draw 'much' more current than they did when new ...
until they approach end-of-service, when the amount of current drawn noticeably increases.
Seems like a stretch to me too. Persons talking about it said something about bearing wear / drag. All the automotive electrical motors I've taken apart seem to fail due to brush wear with bearings in great shape. Unless dirt got in my fans somehow I don't see a bearing going out and if it did, I'd imagine it'd fail in a matter of minutes while making a lot of noise.
mikez71
Are your fans old? Possible they will cause overheating on the new relay wiring as well?
I opened one up just now.. (I already bought new motors so I don't have to re-assemble this one!)
This one was somewhat scratchy feeling, and was a little squeaky too.
But all my old fan motors feel scratchy when turning by hand.. I guess that is just brushed motors..
(2nd version 700W motor.)
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Yeah measuring current draw is simple enough. I'll do that.
Although I'd be really curious about what these fans looked like on the inside! You could rebuild that! Really cool!
I've rebuilt a starter before. It's a similar motor in concept. You replace the brushes. I also lightly sanded the commutator. Lastly you can check the friction surfaces / bearing & shaft. If they're not scarred it could be something else... if they are scared can lightly polish, put a little silicone or lithium grease and put it back together.
I also tried to rebuild window regulator motors. The brushes fail on them. I think our trucks have Siemens motors for those. The design is such you need a jig to put it back together. I cannot recall what bits I couldn't get enough fingers to hold for reassembly.
Thanks @mikez71
BadDaddy2003
