gmartin1215
Glenn
- Joined
- Nov 9, 2012
- Posts
- 373
- Reaction score
- 223
Hi
2009 Tahoe with 4" lift without the auto-ride
I recently changed tires and went up from 280/70/17 to 285/75/17, so they are the same width but taller.
After rolling from the tire shop, I got warnings on the dash for the ABS, the stabilitrack off, and a message to service the stabilitrack. I checked the ABS lines inside each wheel well and all looked ok. At this point, I suspect I will need to reprogram the ECU for the different tire size. Thoughts?
If reprogramming does nothing, Can the stabilitrack be disabled somehow so I don't see the annoying messages?
I did get the COO50 code for the right rear speed sensor erratic/malfunctioning, so I will put some focus there. Any tips/suggestions for remedying this would be appreciated.
