Wheel sensor or something else? [Solved? Not Really]
fozzi58
North Jersey
OK so here is a weird one. My truck was recently lowered again, about 1" and mechanic was able to pick up about -1.5 camber with the Belltech coil overs. I also went down from 24" wheels on 305/35 to 22" on 295/35. On hard left turns at 40mph or higher, it feels like the ABS is kicking on for the right caliper. It feels like the suspension is "wobbling" during the turn but if you pull over and yank on the wheel etc, everything is solid.
I passed tech inspection Sunday when I raced but didn't think much about it but I did notice my left hand turns almost felt like they were a bit slow on the course. It wasn;t as noticable on the couse cause its a rough parking lot and you are accelerating and slowing down to get around the cones.
While changing the geometry of the suspension obviously changes the handling characteristics, I don't think that wobble is suspension related and I think the ABS may be kicking on, during those sharper left turns. It seems to only happen on left turns where it feels like the truck gets a slight "yank" to the right thru the turn. I did a couple of hard rights on exit ramps and I don't get the same sensation thru the steering wheel or body roll.
I have not programmed the new tire size in yet but the last time I switched to the race wheels for longer than the track event, it only messed up my cruise control not working (and the obvious mismatched speedometer). I'm thinking wheel sensor. My mechanic says possibly the wheel bearing if not the wheel sensor.
Side bar - I was going to pull the ABS fuses on my ride home from work today and see if I get that same reaction on a hard fast left. However, I am a bit skittish about pulling the ABS fuses only cause I don't know if the brakes will actually work. Not something I want to try on a public road? Maybe I should go find an empty parking lot? I'm old enough to have driven cars that don't have ABS so its not a frightening aspect to me - I am just worried that if the ABS is disabled, my foot will end up on the floor and only the e-brake to stop.
SO I guess 3 questions remain. Will the truck stop if I pull the ABS fuses (ABS system, ABS pump fuse). Do you think this issue is a dirty\bad wheel sensor or should I be going for a hub bearing?
I have another AutoX event Saturday but more importantly my first road race track event on the 12th which is what I really want to be prepared for. Suggestion welcomed. Thanks in advance....
Do a drive out where you can immitate the conditions while monitoring the 4 abs sensors and see what it shows. Otherwise it's just a guess
fozzi58
fozzi58
North Jersey
UPDATE
Def not a tire rub. I jacked the front of the truck up and spun the wheels on both sides while someone turned the steering wheel. Went lock to lock and no rubbing. The 22's with the low profile tires cured all my rubbing issues.
I removed the wheel sensors from the hubs, and thoroughly cleaned the surface where they mount. Used a little sandpaper and then emery cloth to get rid of all the rust that was creeping underneath the surface mount areas. Cleaned the sensors and reinstalled. Went for a drive and I couldn't get enough speed on a turn to see if it happened again.
On way to work this morning I set the cruise to 57mph and took a left hand off ramp on the long way to work. It yanked the wheel again. However, I did see the traction control light come on. I either missed that or it didn't come on before.
I have my laptop and my HPTuners module with me. Gonna program the correct tire size in while at work and take her for a test run.
fozzi58
fozzi58
North Jersey
UPDATE 2
Replaced wheel bearings - didn't do anything.
Pulled ABS fuse - couldn't drive the truck cause puling the ABS fuse (fuse #35) disabled driver assisted steering - WTF? Its almost like having manual steering, not quite as bad, but it doesn't turn like I need it to. It would be a lot of hand over hand on a high speed turn.
Disconnected one of the wheel sensors on the spindle. Threw expected codes, disabled ABD, park assist, TC, but also said Driver assisted steering was reduced. hmmm. Took her out for some spirited driving.
Gawd DAMN! This beast can make turns! I had a rough day doing AutoX on Sunday and now I know why - the ABS must have been kicking on like crazy and I didn't notice it on the dash even though I felt it in the turns. I'm not even exaggerating when I say my Burb will kick my TA's ass on a turn. I haven't even played with the compression and rebound yet on the coil-overs but its like driving a train. The turns can just keep getting sharper and faster...and it wants more. OK enough bragging.....
Anyways - I've been doing a deep dive on the interwebs for the last 3 hours and looks looks like Vette's and Camaro's are facing somewhat similar issues. Basically the ABS's algorithm is sensing "ICE" so it starts applying braking etc. I am quite sure that the stabilitrack algorithm in the SUVs don't have any "track mode" settings hidden inside.
So basically I am going to be forced to run with an ABS sensor disconnected in order to drive aggressively. The super grippy Eagle F1s, with the lowered stance, stiff suspension and ridiculously capable cornering ability are too much for the factory Stabilitrack to handle. I will have to reach out to HP Tuners to see if some of this can be tunes out thru torque management or some other method. The only other option is to put a manual switch between the gyroscope and the computer and manually disconnect it.
If anyone else is crazy enough to turn their SUV into a track machine, I'll leave whatever findings here in this thread. Maybe I can save someone from wasting a $1000 on wheel bearing they don't need.
UPDATE 2
yep nannies suck. I would experiment with pulling other fuses instead in the meantime, maybe traction control.
fozzi58
fozzi58
North Jersey
I'm going to try that today and also see if pulling the fuse for the ABS pump which is separate from the ABS system will allow the steering assist to work with the ABS pump disabled. I think I am going to experience the same results but I thought it was worth a try.
Gonna have to kick up my tuning skills and see what the torque management can do.
Marky Dissod
If ABS stops working for whatever reason, your brakes will work like your dad's did.
ya, but that sucks, if it does it intermittently it can do more harm than good
You may be right about that. I remember when ABS used to wait until the tire stopped spinning, as in, it let the tire lockup before unlocking it.
End result was that large skids became smaller skids, instead of not being skids.
ABS still does the above, but it has also become far better at not quite locking up in the first place,
which actually helps prevent skids and gives the Stability Control one less thing to do.
to me it becomes a hindrance when it is not working properly, like when you are braking and expecting a certain result and that does not happen it just has a spasm and fails to perform as expected, then you are forced to take other corrective action. On a track all alone that may simply result in running over a cone or barrier or getting your timing messed up, but on the road that's a potential accident waiting to happen.
Marky Dissod
to me it becomes a hindrance when it is not working properly, like when you are braking and expecting a certain result and that does not happen,
The better the ABS works when it works, the worse it gets when it fails.
CMoore711
I'm experiencing this as well with my 2013 Escalade ESV. I haven't dove into trouble shooting it as much as you have, but was really hoping it was just a faulty wheel speed sensor, or chaffed/damaged wire going to the wheel speed sensor as I've read that can be a common root cause of this.
Like yours it happens mid-turn in either left or right directions, but seems to more so when turning left. Everytime I see the orange "traction control" light illuminate on the dash and power is cut off mid-turn. I purposely put "traction control" light because even if I disable traction control and stabilitrac there's an orange light on the dash indicating those 2 systems are turned off. This situation still happens and a different light that looks exactly like the traction control light, but slightly smaller blinks on the dash and goes away once I've exited the turn.
Chevy1234
