West 1
- Joined
- Jan 20, 2023
- Posts
- 704
- Reaction score
- 1,516
An oil pump can last a very long time. I only changed mine because I thought the Melling offered more flow. Finding metal in the pan is. Never a good sign.
Just a quick note here to make sure the record is right for future readers, the L96 has an iron block. I own one. But I agree with you that it's a great replacement for an L92. Runs great on regular gas and built hell for stout.If I were you I’d have a local Indi or diesel mechanic keep his eyes out for a GM 2500 or 3500 that’s wrecked with a good 6.0L L96. They have alum block, iron heads, runs on reg fuel and later versions on e85 too.
www.onallcylinders.com
don't do this, same reason you don't double up on oil filter gaskets, 2 will leakso I doubled up on the Mahle Oring. 2 of them are now installed
I added one like that when I rebuilt my engine. There's already a drilled and tapped bolt hole there, unused. Might as well apply extra preventative protection.
I put one in my cart for future use.
I currently own 3 vehicles with LS engines.
Apples to oranges comparison.don't do this, same reason you don't double up on oil filter gaskets, 2 will leak
i disagree, here is whyApples to oranges comparison.
Doubleing up on a O ring in this situation Can't hurt.
Oil filter is a entirly different situation.
a single o ring fills the void between the metal surfaces, sealing happens
since the o ring(s) being used are the wrong size they are not sealing between the metal surfaces as such the two o rings need to seal between themselves. The o ring to o ring connection will leak.
this is the same situation as dual filter gasket, leak will occur between the gasket/o ring connection
