St. Louis
wierd I thought they showed different but I think I only had the message come up twice in the last 7 years
Yeah I use the overhead switch a lot while sitting in it while running to open/close the liftgate. Like when picking up groceries or something and they bring it out to your vehicle.
mikez71
mikez71
reminds me, I need to order one!
Mine's been broken ever since I got the truck a couple years ago and rubber is all gone..
and button guts I suspect as well..
Shouldn't be a low battery. Just replaced it less than a year ago.
My alarm (horn honking) just went off about 10 mins ago while it was just sitting in the driveway. Haven't driven it at all today. I looked at my security cameras and I saw nothing, 4 legged or 2 legged that could've set it off. But at the same time I could hear another milt-sound type of car alarm going off a few houses down across the road.
What would cause the factory alarm to sound, the door opening? Ignition starting without chipped key? Shock/glass breaking?
A low battery can set off the alarm. Check her state of charge with the Tech-2.
5StarCustmSolutns
Almost Heaven, WV
Ok well, I haven't done anything to it yet.... But in 4.68hrs I'm embarking on a one hour drive that will likely result in my building an OE track width Pre-Runner? Picking up a pair of Fox Factory Series 2.5 Remote Reservoir front coilovers. They are 4" longer than factory at 23.46". And I plan to upgrade the reservoirs to the new DSC high and Low speed adjustment dial system.....
14Tahoe
Just a friendly reminder to change the plastic Ts and the hoses going to them from the water pump. I previously changed the Ts but not the hoses. One of mine cracked yesterday and left me on the side of the road while it was 95 degrees outside.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Yeah I try to remind everyone of that fitting, it often get's overlooked. Here is a Delco one that you can just clamp the hose to. Maybe throw a spare in the glove box too.
j91z28d1
guy at work has a 08 truck with the 4.8 in it. tapping like crazy, heard it across the parking lot at 430am. I walked over to talk to him, he's like it's been like that forever. revs it up and it goes away, idles for a bit and starts tapping again. 200k and he says the truck 4.8 never had the afm. truck didn't even have oil pressure gauge on the dash and he's never looked. just when it gives up its going to the junk yard. not worth fixing.
kinda wild just drive it around tapping. he said it sometimes goes away for months at a time and then comes and goes.
lol, my 03 silverado that I sold to my sister does the same thing 284k+ on it, taps at idle after sitting for a minute and comes and goes usually months at a time, it's good truck, she refuses to sell it back to me.
Rank amateur here but is it possible the ecm is misreading the MAF input?
dealer said they took a look at it has high exhaust pressure, suspect 3rd cat is clogged, so they said get that looked at and put the stock airbox back on it and bring it back and then they can get more accurate readings
Writefast
Hopefully that fixes everything.
j91z28d1
I'm surprised they last so long tapping like that.
Drewphil
