Z55 rebuild or bilsteins
Ilikemtb999
Ilikemtb999
Denver
That’s a common thing to say about putting good money after bad on an 09 LTZ you paid $7k for. It’s actually just the opposite though.
My rig was stickered for $88k when new in 09. 11 years later I picked it up for $14.5k. Last year, after 4 years of ownership it got a new trans, all fluids flushed, $5k worth of deferred maintenance and it was only $6.5k to getr done.
The trans rebuild was $5k but the deferred maint was the parts cost from R/A. With the trans coming out all parts are bolt off & on with trans replacement.
If you want to drop it more than 2-3” there’s no need to discuss keeping the autoride.
My last Tahoe had a 2/3 drop. I enjoyed it. Started life lifted, I lowered it then eventually went stock rear height and level block in front to sell it.
petethepug
Michael
SoCal
Gotcha, looks like the best advice to get is from the one who’s filling out the project build sheet on the LTZ.
Ilikemtb999
Ilikemtb999
Denver
I appreciate your knowledge on z55 replacement stuff but my original post mentions asking about people who have swapped out z55 for something else. I get that you seem to like oem things. Sometimes there’s better, sometimes there’s worse. Again, I’d like to hear from people that have gone the other route too.
Twov8sandat4
After going through two compressors, I swapped the entire suspension out for the Monroe setup F/R. Not entirely happy with it as those were meant for 18" wheel/tire trucks, and my Escalade has 22s, so it doesn't have the "give" the 18s do. Rides nice on the highway, but it doesn't like bumps. Not going back to the stock setup, so I will be on the hunt for something that will work with the 22s.
Big Mama
Virginia
As mentioned several of us have gone away from oem and returned due to poor ride quality and sometimes unsafe handling. In my case the rear was too bouncy. The front was ok but the non oem strut spring combo raised it 2” which negated my drop spindles.
Gearz
I have a 2011 LTZ W/Z55 and the shocks have lasted for 13 yrs with no problems. Go OEM or you’ll regret it! My rear compressor let go 2 yrs ago but the shocks are in good shape so I’m not replacing them until there bad.
Grady_Wilson
Wyoming
FWIW - When the steering angle sensor went out in the middle of winter it disabled the Stabilitrak and the Traction Control systems.
It was a night and day difference in stability on snowy / icy roads with both disabled compared to when the entire system is operating properly.
So, if you live where weather may be an issue, you may want to stick with the OEM Z55 setup.
Ilikemtb999
Ilikemtb999
Denver
I live in Denver. I can’t imagine the tcs or stabilitrac not functioning when running resistors. Worst case scenario it would be like when I daily drove a 2wd Silverado that didn’t have tcs, or my Roadmaster wagon or my k5.
Grady_Wilson
Wyoming
With resistors, your stability system is only going to get a single reading from each shock, meaning the system will not receive accurate, live feedback.
The system may function with the resistors but it will not be as responsive as it would be with live feedback, but if you're good with that, then the added responsiveness shouldn't dissuade you from doing the Z55 delete.
Ilikemtb999
Ilikemtb999
Denver
Would it not rely on the yaw sensor like tahoes with stabilitrac and standard suspension?
Grady_Wilson
Wyoming
The yaw sensor is one piece of the overall system.
If the shocks didn't provide feedback to the overall system, why would there be electrical connectors for the shocks?
The ride height sensors take care of overall ride height while the in shock sensors provide feedback on the position and speed of travel of the internal piston inside the shock.
The Stabilitrak is actually a pretty great system when operating properly.
Ilikemtb999
Ilikemtb999
Denver
I mean I get that they’re a part of the equation on something with z55 but with the shocks out of the equation I can’t imagine it not being similar to a lesser suspension Tahoe with stabilitrac. Are you saying that lower trim tahoes are dangerous then?
Grady_Wilson
Wyoming
Where did I say any other system was dangerous?
I'm just saying that the shocks are part of the overall Stabilitrak system and removing them will make the vehicle overall less capable in slippery conditions.
I was just giving you an idea of what eliminating the shocks would do, you can decide on your own.
Good luck with whatever you decide, I'm out of this thread.
petethepug
Michael
SoCal
When someone asks a question or, for advice, it’s up to that person to pick & choose what works out best for them.
Plenty of suggestions, advice & knowledge has been gifted on this thread. Some of the circumstances relating to the original questions asked have changed. That changed a lot of the answers previously provided.
I’ve never seen a bunch of forum members be more patient & supportive of trying to get you where you asked to be. The individuals who gave you sage advice are looking out for you, your passengers, pedestrians and the other drivers you’ll next to at 60-80 mph.
This advice and answers your seeking would be different if this was a track racing, off road or desert forum. I hope the info provided to you helps in some way.
West 1
I will share my only experience, we had a Cadillac Escalade with the same Z55 system, shocks went out and think the car was at 175,000 miles I replaced with high quality standard shocks. I was fine with the ride. My wife on the other hand has had neck surgery and right away complained that it was much more jerky over bumps and irritated her neck, when her neck gets jerked she has headaches for 2-3 days after so I was in deep doo doo for that change. I just did a Yukon Denali, same job, this time I went to the Factory type shock again. Used Arnott AS-2708. Has worked out well so far. You know the saying, if Mama ain't happy nobody is happy. It is true.
the blur
Cyber Space
My LTZ has a torn rear shock, and the compressor is dead. So what exactly am I riding on?
The answer is ... just springs. The shocks aren't doing anything.
a1parrothead
