Geotrash
Dave
Richmond, VA
Wiring Harness Swapped out - so far so good.
Gonna dump some "tech" info for incase anyone else has a P0340 code with a DoD motor.
The P0340 is a circuitry error, so likelihood of the sensor being the issue is low - possible - but low. When looking at MY particular swap, the new LS3 ( i think it was LS3 front cover ) had the camshaft sensor and its connecting harness, that was a 3 wire sensor and harness. To interface the harness, there was a little jumper between my factory 5 pin harness that converted it over to the 3 pin, which was a jumper about 3" long or so. This is what had become unclipped from the bolted on harness on the front cover. The ICT Billet harness is a solid 10" or so and it goes from the main engine harness directly to the sensor, so it eliminates a connection point. Tip for replacing the harness, take the 5 seconds to take the serp. belt off. The wiring is in this metal bracket, held on w/ (2) 10mm bolts. The ICT harness could just connect from harness to sensor and be done, but I mounted it into the metal bracket, that cleanly keeps the wiring out of the way of the pulleys. The one modification I had to do with the harness was on the sensor end, there was a little plastic tab that was hitting on something in the sensor, I just cut it out for clearance and it plugged right in. Now it is configured basically how the stock sensor is, and so far, no CEL is or has come on. I do need to drive it more to verify this, but it was turning on every other day or so. It does seem to take fewer cranks to turn over and start, and the idle seems to have smoothed out as well.
For now, im going to caulk this one up to an issue with 1 of the 2 harnesses that were used to switch over from the 5 pin ( VVT ) to the 3 Pin ( non-VVT ) sensor.
Thank you for this. It may well save my bacon down the road. I had to use that converter harness for my cam swapand it’s just a little short so it strains the sensor pigtail. As Monica also asked, please do post the details of the ICT part.
Fubar0715
Scott
Southern New Hampshire
It's almost too boring doing roadtrips in them because they just get on the highway and just cruise. Im getting ready to take mine down to the Gulf Coast again and its just 70 mph, cruise control and point it in the direction you want to go.
Same boat for me - I will be heading to Florida to pickup a semi restored VW Karmann Ghia I purchased last month. Looking forward to the 2 day cruise down, sitting on the couch of a seat, and cruising along peacefully. Last time I made this trip, little over 1300 miles - one way so should be a nice drive.
justchecking
Military
SW Ohio
Always liked those Karmann Ghia’s. Wish I had one of my dad’s two VW Things. You trailering it back? Post pics!
Fubar0715
Scott
Yep, I have it stored at my brother's house at the moment. Gotta get me a 4 post lift now to stack the Mustang and the Karmann Ghia in my garage - thankfully, I got like 14ft ceilings with a 24 depth from the door.
Grady_Wilson
Wyoming
I plan on getting a 4 post lift installed in my garage once I move.
I need to make sure my new garage/workshop has high enough ceilings for one and I need to make sure I get a lift that will go up high enough to drive a stock 1920's automobile under it.
Charlie207
LFOD, New Hampshire
New front diff oil. Squeezed in some Lucas 80w-90, after draining the old gunk out, and cleaning the magnet off. Lots of sparkles, which pretty much confirms that the whining is the bearings failing, but which bearings?
There was at least an 1/8" of schmutz on the magnet.
j91z28d1
this was my rear diff when I got it.. with 130 something on it. dead quiet still but it does seem like a lot.
this was my diff
I didn't take any of the front, but it was ugly too. so far thou no side effects from it. so it doesn't always mean it needs rebuilt, but if you got whining. yeah blah.
Fubar0715
Scott
Look for a high lift - most of the '20s cars seem pretty tall - similar in height to our Tahoe/Yukon/Esky trucks
Grady_Wilson
Wyoming
My 1926 is taller than my 1929.
By 1929 cars started getting a little lower than the really old, tall passenger compartments and overall profile.
My 1929 Pierce Arrow is very heavy, coming in about 5,000lbs on a 143" wheelbase so it will be on the ground while my 1926 Rickenbacker is taller but much lighter being a smaller car.
Charlie207
LFOD, New Hampshire
this was my diff
Your front looks like actual metal shavings, whereas mine looked like sparkling bearing flakes (ground up mica).
j91z28d1
Less than two years, only using Auto or 4Hi occasionally, even in the winter. Waaaay less than 20,000 miles.
ahh yeah 20k you probably got something eating itself.. if it was the first time it had been done with 100k plus on it. it would be expected.
probably time for full set of bearings and hope the gear looks ok?
Charlie207
LFOD, New Hampshire
Yay. I wonder if the previous owner left it in AUTO most of the time.
I wish the front hubs had the ability to stay together without the axles installed. That would give me time once the snow goes away to leave the front diff & axles out while I tear it apart, and have a shop install the parts. (or a buddy with the presses/pullers).
St. Louis
How does a 2wd do it?
Charlie207
LFOD, New Hampshire
RWD GMT900s use different front hub assemblies. The 4WD front hubs utilize the front axle /CV stub and nut to keep the bearings together. I suppose if I could find some worn out 4wd front C/Vs, and rip them apart to use just the stub to hold the front together while the diff is getting R&R'd it would keep my front wheels from detaching at highway speeds.
RWD front hub assembly:
4WD front hub assembly:
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
View attachment 422312View attachment 422313
That is exactly what I did with the old CV's I removed/replaced. I disassembled them and saved those stub shafts/nuts just for this.
St. Louis
I thought I've seen something about people using 4wd hubs on 2wd vehicles.
I don't think the axle stub/nut holds the bearing together. The 2wd model just has cover plates to keep out dirt and shit.
EDIT: I guess it depends on the hub manufacturer and model. Some can, some can't. Some manufacturers use the same hub for both 2wd and 4wd applications
Charlie207
LFOD, New Hampshire
Not sure, but I'm not about to be "that guy". I suppose they manufacture two different designs for a reason.
And it would be weird that the axle nut torque spec. is like 188lb./ft., which seems like an awful lot to squeeze the outer C/V into the hub if it didn't do anything.
I've been doing some Googling, and seen both answers: does nothing and can run 4wd hubs without axles with no problems, or tempting fate by not having them installed. If I can find dead axles and chop the stubs off I might as well throw them in for that hypothetical situation.
Hodmjstone
