What year would you avoid in a Tahoe or Yukon?
gmgirl77
I have no choice but to trade my 16 Yukon in at this point. Between the no click no start, and the continuous electrical drain that we are unable to find. I cant keep paying this much for something that sometimes starts, especially with winter coming.
I thought this would be easy and I would buy a new Tahoe RST but Im not loving the lack of amenities in it. The dealer showed me a 19, but looks like they also have some serious electrical issues as well.
Does anyone have a year that they can recommend that seemed ok?
Thanks
Ibustbravo
Centennial, Co
I only know the year models that I have. 2015-2018.. I think they're all good vehicles with good engines. I feel like I lost on the 'get a newer model year' gamble though.
If I were to do it again I'd find a super-clean gen 3 or 4 suburban with a billion miles on it and replace the engine and trans straight away. As opposed to paying 50K for a 3yr old yukon and only getting 4 years out of the engine and trans before I had to replace both..
Hindsight is always 20/20..
C
GMT800 2005 Tahoe Z71
Navy Supporting Member
I can only speak for the NBS era. Less bling but more reliable in the long run, IMO. Way more comfortable too. When I bought my 2005 Z71, I could afford brand new but like @Ibustbravo said, I would rather buy something older and do an engine and transmission and pocket the difference.
thegrunter
Not sure if the Tahoe ever got the 8 speed tranny like the Silverado, but I would say those years based on the Silverado issues. I think the Tahoe went from 6 to 10, but I am by no means an expert on that.
gmgirl77
gmgirl77
Kind of depends where you are. If you are up north, anything older than 8 years is gonna be a rust pit. If you are down south, I’d consider a 2012 or 2013 if you found one not too high miles. Or, dive in to a new one…
Thanks, I am up north. I do garage my vehicles and wash them regularly. I wish I could just keep what I have, but this electrical issue is out of hand. Nobody sells their vehicle because they love it. I guess I could always get an extended warranty.
gmgirl77
gmgirl77
Yes, they are all 10 speed now I believe. I havent seen one that is a 6 so far.
WalleyeMikeIII
Sunny and Snowy Minnesota
Suggest taking to an independent shop and maybe have someone check all the grounds…GM notorious for botching the ground system and it causes all sorts of bad and hard to diagnose stuff…
Ibustbravo
Centennial, Co
It might be time to break out the expensive tools and start working through it. I'd loose my shirt if I gave up on my yukon, it's paid off as of last month. Haven't been able to drive it in a year.. I'm determined to have an error free truck at this point.
Here's my suggestion. Get an alldata.com subscription.. It's $20.. Below the 1st link is a link for the MDI2.. the original. You can go a bunch of different routes with this, such as the other bosch ADX tools or autel..
https://www.boschdiagnostics.com/diagnostic-systems
Once you get the GM MDI2 J2534 hardware.. you get a subscription.. https://www.acdelcotds.com/subscriptions.. You want this subscription--> GM Light Duty Global Diagnostics 2-GDS 2.. You get three days.. If you combine that with an alldata subscription you have all the pieces of the puzzle.
StephenPT
St. Helens, OR
Definitely NOT a 2021-2023
Apparently they have special wiper blades that can ONLY be bought from dealer/OEM
It’s a top lock push design. Not your typical j-hook that everyone is familiar with, but nearly every aftermarket wiper blade includes the adapters to adapt to TLP. When you buy new wipers you get little pieces of plastic that you always throw in the garbage. One of those is the adapter you need.
Check RockAuto - there’s a ton of wiper blades that will fit the ‘21+ platform.
Thanks
I would just invest in new battery cables, starter cable, clean the grounds and add a couple extra of your own grounds in good spots.
$200 in parts and you should be ok, might be worth a try anyway, cheaper than another car payment.
electrical drain can be found you just have to follow the troubleshooting procedure properly, if you follow procedure and cannot find a drain then it doesn't exist.
St. Louis
My post was sarcastically referencing a post by @Blueinterceptor in the UAW strike thread about certain models taking special wiper blades that will be hard to find
Blueinterceptor
I thought wrongfully that these (wiper blades) were unique to gm. I apologize for being wrong. But I’m glad I am wrong.
The point is that if you need a gm part you may be waiting some time if your dealer doesn’t have it.
StuckinMN
Suggest taking to an independent shop and maybe have someone check all the grounds…GM notorious for bitching the ground system and it causes all sorts of bad and hard to diagnose stuff…
Check the grounds. Then check the grounds. And once done, check the grounds.
