Update. We pulled motor yesterday. Found a couple things but sadly, all for nothing.
Backing up. When we pulled pan and timing cover last weekend, we swapped in
New Melling 10355HV High Volume/Pressure oil pump.
New GM VVT sprocket
New Melling solonoid valve
New GM Timing cover magnet
New pickup o-ring
Another reseal
Started up, hit almost 80PSI cold, then dwindles down to 5psi at operating temp, will drive but soon sets P0011 code and stabilitrack and will die and not restart.
Again, new engine built last year, installed a few months ago, less than 2000 miles. Was honed to 4.070, new DSS forged Pistons/moly rings, all new rockers, pushrods, lifters, trays. Polished cam, new cam bearings installed by engine machinist.
We found wrong valley cover gasket, but worked, and cam thrust plate had weird indents in the gasket. New gaskets again, new cam plate, pulled all rod caps and a couple main bearings to inspect, all are good. New barbell and rear cover gasket.
Cam bearings didn't appear to walk and upper 3nd looked good so we didn't pull it after finding the wrong valley gasket and maybe damaged cam plate gasket. We plugged the oil pan relief valve also.
We are losing our minds. 75psi swing in oil pressure... Gotta be bleeding out internally but can't see anything. Can the VVT be bad and dump oil electronically once warm?
