07 Valley cover
j91z28d1
if you jump to 23min in he has one that doesn't want to release and uses a scale remover as a little air hammer for it.
I was wondering since yours has probably never been released that it would be stuck with varnash. that red tinted stuff inside most engines, that doesn't really come off without spraying brake clean on it.
I've not done this myself, only read about it a lot. do you have the rocker arm off and the push rod in the lifter cup, so you can see it pop the rod out when it breaks free? and then push down by hand and pop it back into it's normal position. he says most of the time when it releases it will over extend and needs to be popped back do a bit before starting it.
I'd also soak the brake clean down the pushrod hole and let it soak into the lifter and valley hole in hopes it loosen any build up as a last resort
C
crownvic31
Head coming off tomorrow. Im exhausted. Nothing helped this one. I am working in a in door public parking garage with hand tools. The rocker arm is off and the pushrod left in place. It bounces and bounces and bounces. The valve releases some but not enough. I push in the pushrod back down and goes way down.
j91z28d1
damn it man.. that's a shame and a horrible place to work.
post up what you find when you can.
Dustin Jackson
I would consider taking both heads off and removing the cam to inspect for damage and at that point you might as well rebuild it with new non AFM parts
C
crownvic31
As much as I would love to do this but right now its not the time. My plans are to keep this repair as simple as possible and get my escalade up and running. I will remove passenger head for sure and inspect everything. Everything on the driver side looks good when rotating the engine. If I do remove the driver side head, I will simply just replace the lifters and push rods and keep everything esle. Ive never had issue with this truck. If it would have not been for the valley cover situation, I would have not been in this mess.
Is it just ok to replace the lifters and rods on one side of the engine? Do I even need to replace the pushrods?
donjetman
Don't put new lifters on a damaged cam or you'll be back in there sooner than later.
C
crownvic31
So if the cam is good then I can just replace that side or just do the one?
Lets remember that the knocking was only about 3 mins and then it just stopped and the misfire started. How much demage could had happen in that short time while just idling?
It had zero issues until this damn valley plate swap. Man do I regreat this.
Geotrash
Dave
Richmond, VA
If you're planning to replace the lifters with the same type that comes out, then yes you can just replace the lifters on one side. Be sure to replace the lifter trays also with *new* OEM only. If none of the pushrods are bent or damaged, then you can reuse them. Get a really good look at that cam though - Don is 100% correct.
C
crownvic31
Thanks. Yes i will look real good at it once the lifters are removed. The front and back of the shaft look real real good. Truck has 130k miles.
j91z28d1
check that you can find oem afm lifters. for a while they were hard to find and like said above. anything but the oem lifters and plastic trays seems to be a temp fix. they seem to be pretty expensive too
pulling the head in a parking lot is brutal and without air tools. you do what you gotta do but ouch.
would love to know what you find out after you get it all back and running. the lifter moving a bit but not popping up completely is rough... I haven't seen any comments or anything about that happening. The general consensus seemed to have been they were either stuck or not stuck.
donjetman
The guy in the video used an air hammer to get the bad one to unstick. He wasn't being successful with the hammer.
C
crownvic31
I wonder if i should bang it some more. The tool actually bent alittle
j91z28d1
I was wondering if you banged on it to release it the little bit, and then pushed it down, did that over a few times if it wouldn't work it's way higher and finally lock. but at this point you've spent so much time on it and I can imagine being sick of laying across the engine that I figured you were sick of messing with it haha and ready to just rip it apart.
are you 100% sure it didn't release and your feeling that little bit he talks about it clicking back down on the pins from over extending? just wondering out loud at this point.
C
crownvic31
IT JUST RELEASED. WENT FLYING
NOW WHAT? Did i do to much demage to it or should i put it back together
j91z28d1
I'd do the little tap on the push rod that he shows to make sure it is locked in.. inspect everything the best you can. put the rockers back on, turn the engine over by hand to make sure it's moving the rockers, then at this point I don't know what it would hurt to try starting it?
C
crownvic31
She is put all back together and she lives. What a relief . I believe what did it was the wd40 i sprayed in the valley hole and in the little hole on the pushrod. I let that sit over night. So after work i went at it again and gave it 5 good wacks and pushrod went flying. I reinstalled the pushrod and turned the engine and it starting moving up and down. Turned it several times and it was all good. Went ahead and installed everything and smwent to crank it and she turned and sounds beautiful. THANK GOD!.
Thank you all for all your advice, time and patience . I can now sleep in peace tonight. I did not drive it as i want to change the oil . But i did crank it several times and let it idle for a good 10 mins everytime. All is good.
j91z28d1
that's awesome.. going to be the best nights sleep haha.
hopefully it all stays running well for a long time. what did you do with the vlom?
and I bet you're right, the wd40 probably was the ticket to breaking up what had it stuck.
C
crownvic31
Vlom went back on. I didnt do the vlom mod. I didnt want to take any chances just in case.
ScottS-Michigan
