So round trip travel time was about 40 minutes?
43 mins. Stopped off the highway to water some weeds at an entrance to someone's hunting property.
Just one at the top. They're wedged in pretty well otherwise.@Sparksalot, How many attachment points per flap? It's looking like one up top and one near the middle?
Heard a HISSING sound! From passenger side of motor when shutting down after a drive... Lasts about 15 seconds or so
Previously thought it might be A/C pressure bleeding down, but it definately sounds like it's coming from the top of motor.
I think this maybe the coolant smell/leak? I've been chasing.
I'm thinking it could be the rear steam port or external headgasket leak on top, but under intake manifold.
Anything else it could be?
I will remove intake in a few days to have a look see... What else should I do while I'm in there?
I bet some needles fell out and are crushed into the end of the cap.presuming the snap ring was fully inserted to begin with how much force would it take to push it out like that? i'm presuming a lot
And hot and humid and fkn Canada smoke GRRRR!!!!
108 Here today
Right on, thanks! I'm REALLY hoping it's the steam ports and not the HG!Bruh. I had a thought when I first woke this morning (or maybe last night or maybe even in a dream) about them block-offs at the back of each head. The gaskets rarely fail, but it's not impossible.
Yes, it was level, but my phone was tilted. That spot was angled very slightly towards the front, but was level from left to right. My driveway isn't level and I can see how my rear axle is slightly tilted so that's a no go for ALC.did you do it on level ground, I only ask cause it doesn't look like level ground in that pic?
I don't think a full tank matters too much, it should compensate for it.
Yours might be good, I can tell mine was harsh over small bumps, more of a rattle than normal suspension damping.
had it towed to the dealer this morning they replaced the rear u-joint and said the front one was good (there main tech did it), then I had the wheels balanced and it is 80% better, but not quite there yet. you can still feel some vibration cruising and at 110 it kicks in a lot that's as high as I took it, called the driveline shop to see about having it balanced they can get it done Wednesday he said the drivelines are balanced with the original u-joints that are epoxied in and changing them can cause some issue, but that could just be a song & dance I don't know but i'm going to give it a shot and see what happens if worse comes to worse I can have a dorman overnighted for AM Thursday if I get the order in on time otherwise Friday which gives me a 1 day delay on leaving.
I am going to go jack it up and take look at it just for my own curiosity.
most people that drive the speed limit might not even notice it as it is now but really hard to say I can tell the difference but I "think" I am more tuned in with my vehicle because of the way I drive and at 110 it kicks in a lot like it was when picked it up the other day.I hope the balancing works. I have hopes the balancers are better now than when I went thru it.
the autos always hide a lot of the vibration, the manuals have the shifter bolted stright into the rear of the tranny you can feel every little thing in your right hand. so if you can feel anything at all, it's probably more than enough to be bad, even at a 100 lol.
18 mpg driving at 80 mphDriving from Burt Lake to Troy Mich today. Will see what my MPG is.
Order the Dorman shaft anyway, you can always send it back if not neededhad it towed to the dealer this morning they replaced the rear u-joint and said the front one was good (there main tech did it), then I had the wheels balanced and it is 80% better, but not quite there yet. you can still feel some vibration cruising and at 110 it kicks in a lot that's as high as I took it, called the driveline shop to see about having it balanced they can get it done Wednesday he said the drivelines are balanced with the original u-joints that are epoxied in and changing them can cause some issue, but that could just be a song & dance I don't know but i'm going to give it a shot and see what happens if worse comes to worse I can have a dorman overnighted for AM Thursday if I get the order in on time otherwise Friday which gives me a 1 day delay on leaving.
