Heard a HISSING sound! From passenger side of motor when shutting down after a drive... Lasts about 15 seconds or so
Previously thought it might be A/C pressure bleeding down, but it definately sounds like it's coming from the top of motor.
I think this maybe the coolant smell/leak? I've been chasing.
I'm thinking it could be the rear steam port or external headgasket leak on top, but under intake manifold.
Anything else it could be?
Bruh. I had a thought when I first woke this morning (or maybe last night or maybe even in a dream) about them block-offs at the back of each head. The gaskets rarely fail, but it's not impossible. I was gonna reply to one of your posts this morning, but didn't have time to get on the forum.
I will remove intake in a few days to have a look see... What else should I do while I'm in there?
With IM removed? Maybe oil pressure sensor replacement if it's old. Clean and inspect the VLOM for oil leaking (COVER THE INTAKE PORTS FIRST!). Maybe replace the VLOM gasket or, at least, re-torque the bolts.
And hot and humid and fkn Canada smoke GRRRR!!!!
108 Here today
mikez71
Right on, thanks! I'm REALLY hoping it's the steam ports and not the HG!
Oil sender, check. Mine reads 2lbs high, not the end of the world but I'm guessing it's original..
intake ports, check. I will tape over them
I've seen @doubelieve recommend the felpro metal gaskets..
Battery died on Deathscalde in the driveway this morning. Pulled it out and that jank was from 2018 :eek: Glad it happened now and in the driveway rather than last month's trip to Colorado or this week's quick trip to Ohio so I'm thankful overall. ....And impressed that other battery lasted 5 years!! LOL
dkad260
Finally performed the ALC reset on the load leveling suspension in the Yukon.
I replaced the rears with the Arnott last year and finally the front with OE Z55 BDI cartridges. I should have reset the ALC with the new rear shocks.
The ride is good, but have had this slight "washboard" sensation which has been just mild enough to not worry about it too much, but at the same time, enough of it to make you wonder what's going on.
I could tell it was mainly in the rear so I filled the tank, went to a nearby parking garage and performed the reset.
It went through a small series of releasing air....lol, no pump activation then it was finished.
It never looked like it was lifted in the rear, but obviously there was enough air in the system to make a difference.
Ride is noticeably smoother with less "jarring" or "sharp bumps".
Sorry for the bad pic, lots of lights in background. This is the current stance....I can tell it's down about an inch from before, maybe a ittle less.
j91z28d1
huh. I tried running it on mine and it really didn't seem to do anything. I wonder if I'm doing something wrong. I didn't fill the tank. I wonder if it knows and doesn't run the setup if the tank doesn't read full.
did you do it on level ground, I only ask cause it doesn't look like level ground in that pic?
dkad260
Yes, it was level, but my phone was tilted. That spot was angled very slightly towards the front, but was level from left to right. My driveway isn't level and I can see how my rear axle is slightly tilted so that's a no go for ALC.
I don't think a full tank matters too much, it should compensate for it.
Yours might be good, I can tell mine was harsh over small bumps, more of a rattle than normal suspension damping.
had it towed to the dealer this morning they replaced the rear u-joint and said the front one was good (there main tech did it), then I had the wheels balanced and it is 80% better, but not quite there yet. you can still feel some vibration cruising and at 110 it kicks in a lot that's as high as I took it, called the driveline shop to see about having it balanced they can get it done Wednesday he said the drivelines are balanced with the original u-joints that are epoxied in and changing them can cause some issue, but that could just be a song & dance I don't know but i'm going to give it a shot and see what happens if worse comes to worse I can have a dorman overnighted for AM Thursday if I get the order in on time otherwise Friday which gives me a 1 day delay on leaving.
I am going to go jack it up and take look at it just for my own curiosity.
j91z28d1
mine does seem to ride OK, or OK to me over wash board roads but I have nothing but stiff suspension cars with small side walls to compare it too. mine also has the so called no coat option of 17in wheels and tires with more sidewall instead of the normally 20s for a Denali. I just can't help but think mine rides higher in the back now then when I got it and all I did was tow a trailer 2k miles lol. I didn't measure it before thou. so possibly in me head?
I do have the specs to measure the factory ride hight but it's just like gm they can't give a simple fender well to ground spec, it's gotta be under it on a lift measure this suspension part to that suspension part with a special tool lol. I honestly thought that was a corvette only thing lol
blah.
glad yours worked thou. next time I fill this thing up, I think I'm going to redo it just for the heck of it.
j91z28d1
I hope the balancing works. I have hopes the balancers are better now than when I went thru it.
the autos always hide a lot of the vibration, the manuals have the shifter bolted stright into the rear of the tranny you can feel every little thing in your right hand. so if you can feel anything at all, it's probably more than enough to be bad, even at a 100 lol.
most people that drive the speed limit might not even notice it as it is now but really hard to say I can tell the difference but I "think" I am more tuned in with my vehicle because of the way I drive and at 110 it kicks in a lot like it was when picked it up the other day.
poking around online it appears that a balance could solve or it could be something still isn't quite kosher, u-joint not centered properly or bound up or even a needle bearing laying inside one. I will have the driveline shop check all that, which they probably already know lol
j91z28d1
very well could. be a centering thing.
I just always figured heating it up ebout to press the nylon or epoxy whatever out or these days with impacts so strong just hammering on the the big c clamp looking press tweaks the ears or something.
I think you're right, most people wouldn't notice it, but also. if that was a younger tech, I bet he's never. changed u joints in that dealer before. they kinda just don't fail like they used to. when I was first under mine I yanked on it and didn't see any play. I'm not touching it till it falls out. or at least I hope I see or feel the vibration before it falls out haha.
funny I did finally throw a drive shaft on that old car. next to a buddy 3rd gear on the spray hopping the front end up like kids dumb will do with their first kit, it tore one of those thin straps and came out the rear yoke. made a hell of a noise, damaged the floor board and got caught up above the torque arm and the floor board. showering my friends behind me in needle bearings. didn't make it to the races that night haha.
St. Louis
Order the Dorman shaft anyway, you can always send it back if not needed
OldWYLawman
