Rough Idle
Marky Dissod
More I read about E85, more I learn about how it burns cleaner.
Why not start with two bottles of Chevron with TechRon Fuel System Cleaner?
Should be able to buy that at your local automotive store.
Add that to E85, should clean things up pretty well.
opfor2
opfor2
Riverside County, CA
Is it compatible with E85?
opfor2
opfor2
Update: So after running exclusively E85 fuel and 4 bottles of injector cleaner the rig seems to idle a little better however, the roughness is still present. I'm thinking that I may have one or more injectors what need additional cleaning or replacement. My question is how does one determine which injector is dirty without removing them all?
mikez71
Sparkplugs? Recently saw a thread about a bad sparkplug. If nothing else you can see if any look lean (white).
I'm not sure you will be able to see if injectors are clogged, but there are injector cleaning/flow rate testing services..
opfor2
opfor2
Yes I replaced both the plugs and wires with OEM AC Delco parts
j91z28d1
usually the fuel rail has to come off to get 1 injector out, so at that point it's just pulling all 8 out of the rail and then there's a injector cleaner, it's a sonic bath while opening them up and then flow testing them. might be a shop local to you. but most people mail them off. no clue on costs these days, you can probably buy new good quality aftermarket injector for the price but there's a setting in the tune that should be adjusted to the new injectors. offset times for opening and closing vs ign voltage I believe it is. every brand is different and most good ones will provide it. but that opens a whole can of worms if not tuned. so for a daily it's normally easier to just have the stock ones cleaned and flow tested.
Dustin Jackson
@opfor2 There might need to be a certain set of criteria to trigger a check engine light. I used to have a 96 tahoe 5.7 that ran terrible but had no check engine light, when I hooked it up I could see that one of the cylinders "misfire" count would go up under acceleration but never triggered a check engine light.
Could be different with this platform but I think someone would have corrected me by now, it's worth a shot?
opfor2
opfor2
UPDATE: After many bottles of injector cleaner and numerous tanks of E85 fuel my rough idle was still present. So, I ended up buying 8 new OEM GM fuel injectors from Rock Auto and yes that was the issue. I've attached some pictures of the old injectors just so you can see what I was dealing with.
Great and informative update!
What are these injectors rated at? Price?
Dh1280
