east302
Mississippi
Looks like 20 ft-lb for the 8.5”
(from 1998 manual)
dkknaebel
Keeping LKQ in business
St. Petersburg, FL
I actually washed FrankenBetty and put some tire shine on her and took her to Roosterz Rod Shop for a shop party on Saturday. The kid took his C10 with the LS swap. His truck got a lot of interest. He also laid down about a 500' burnout when he left. It was a great little Saturday. I drove Betty today because my daily needed gas in it and I was running late. Arrived at work with a slight head due to the testing of the speakers and amp on my way in LOL
YukonGTmaster
2 Door w/ Barn Doors Club
Pictures?
YukonGTmaster
Its was a slow day at work, so decided I would finally try and figure out why my under hood light would not work with a new bulb in it. There was 12v power at the connector. I removed the assembly, and it was a corroded mess. Took it all apart, sandblasted and scotch brited it. Bathed it in ACF-50 corrosion inhibiter, and put it all back together. What do you know, it lit up!
Its was a slow day at work, so decided I would finally try and figure out why my under hood light would not work with a new bulb in it. There was 12v power at the connector. I removed the assembly, and it was a corroded mess. Took it all apart, sandblasted and scotch brited it. Bathed it in ACF-50 corrosion inhibiter, and put it all back together. What do you know, it lit up!View attachment 396078View attachment 396079View attachment 396080
Do you have the light that's on the reel? It's under the hood--sometimes. Comes in handy.
dkknaebel
St. Petersburg, FL
Mean_Green
Drove Emeralda a bit today (Esmeralda without the s due to the Emerald green paint). Stopped by a few shops to get some quotes. One shop wanted $570 to replace the pins and rollers in both front doors. Another quoted $240 for the same job and couldn't understand why the first was so high. BUT, neither really wants to do it. Too small of a job for them due to the high volume of collision work and custom paint orders. Second shop has a Dodge Viper and a few other equally high end models in their lobby on display.
They suggested a mechanic, but the three I went to say they don't do that.
Upholstery shop quoted just under $500 to do the headliner. They say the whole 'board' needs to come out which means removing all of the side plastic trim, coat hooks, courtesy lamps, HVAC controls, etc. Said I could save a bit if I did all of that and just brought them the board. Not sure I want to try that.
Nobody wants to try to touch up the clear coat. They say the panels needs to be stripped to bare metal, primed, painted color, then clear coated. One casually said $2,500 plus.
Umm, no. I'll be looking into fine sanding and rubbing compound.
Fielding a couple of inquiries to shadetree guys that were mentioned.
Swagfu
Deland, Fl
The clear coat on mine is shot on the hood and roof. I was quoted 1200 to have just those painted. 4000 for the top half of the truck or 7000 for the entire truck. I only went to one place so far though and they are considered on of the best in town. I keep thinking I am going to try another place, but I am so far away from being able to have anything done I don't go. Most places around here are more into the insurance jobs.
Mean_Green
I won't be paying that much either. If I can't find somebody to spot it, I guess I'll have to try it myself. I have a couple of less visible spots on the roof I can practice on.
Headliner guy said I could save some money if I pulled the plastic trim bits. Wasn't sure if I wanted to get into that. Started working on a different task that involved pulling a couple of plastic bits and somehow I found myself with most everything removed and the liner partially hanging loose. Oh well. Went ahead and called the guy back. Have that job scheduled for next week now.
Exhaust had been modified somehow and they used stuff that rots in water. Got referred to a muffler guy. Turns out when he does custom work, he keeps the factory stuff he cuts off. The stuff that doesn't rot when wet. Somehow he just happens to have a factory cut off for this vehicle. So, that's scheduled for next week too.
Cleaned up some more or the rat's nest of trailer wiring.
Mean_Green
^^^ Headlight assemblies in post 6,992 cost me about $80 and really dressed up the front view in my opinion.
I need to do something with the frame rails on the sides of mine. I was just thinking of painting them black, but you have me wondering.
YukonGTmaster
I hit any large scale rust with a metal scraper and wire wheel. Brush or spray Corroseal rust inhibiter on the rust. Then I spray matte or satin black to give it a more OEM look.
vtxtexan
