2013 Escalade ESV DOD full delete becoming rebuild
skpyle
skpyle
Senior Member
Found it...
Piston #1 was quiet. Piston #2 knocked just slightly. The other six pistons were also quiet.
I removed #2 piston/rod assembly. I was able to rock the piston side to side on the connecting rod. That is where my knocking sound was coming from. And explains why I heard it from the front side of under the oil pan.
#2 connecting rod is chucked up in the vise. The play you see is the piston pin rocking in the small end bushing of the rod. The knocking video I posted from May now makes sense.
To be honest, I learned this trick from Eric from "I Do Cars" on youtube. He usually does this to look for wasted connecting rod bearings. I did it to check for loose wrist pins.
When I am off work again Thursday, I will remove the remaining seven piston/rod assemblies. Number then remove the pistons from the rods. The rods and piston pins will then go to my machinist for new small end bushings.
Yes, there is still considerable work to come. As I will likely continue to fully disassemble the engine to clean EVERYTHING again. Then build it back up from a bare block. I already have new bearings and gaskets on hand.
j91z28d1
oh man.. glad you found it. Definitely wouldn't have found that without pulling it out.
doesn't seem like I hear much about wrist pins wearing on a ls. any idea what caused it? I forget the details.. I'm guessing they were the stock rods and pistons?
skpyle
skpyle
Senior Member
Thanks! I am VERY relieved. I was honestly concerned that I would completely disassemble the engine and not find anything wrong.
Same here. I was told not to worry about the small end bushings. They all 'felt' OK when I assembled the pistons to the rods. Yes, stock Gen 4 LS rods with new Silv-O-Lite stock replacement pistons.
j91z28d1
oh man. I gotta think you got a bad piston then. to big of bore or bad heat treat in that area?
ugh.
Simpson21
