Official 00-06 Tahoe/Yukon/Escalade drop guide with pics...
Mudsport96
40.923,-89.488. Illinois
Since this is the official drop thread i guess i can ask here.
If i want to do a slight drop on my 06 z71 MAYBE 2 inches. Would it be easiest to get base model nonz71 coil springs and just turn the keys down a bit? Ive seen that the "purple" gm keys are like a 2 inch drop for the front that may be a way i go too. Any insight is appreciated.
bkbailey85
Did the drop kit this last weekend. Alignment today. I'll get fender measurements after the alignment and then repost measurements again later after everything settles. I might be removing the torsion bars and doing a Viking coilover swap, the tabs on the DJM LCA's are definitely strong enough to support without modification. 10psi in the rear bags make it really stiff and I have no doubts that it will still tow with less squat than stock. Pain in the a$$ to get the bags in the DJM springs, used an A/C vacuum pump to deflate as much as possible.
Front:
DJM 3" drop UCA/LCA
DJM shocks
Eibach anit-sway bar
Cognito pitman/idler balljoint stabilizers
Rear:
DJM LCA brackets
DJM anti-sway bar links
DJM Trailblazer 4" drop springs
DJM shocks
AirLift 60742 airbags (aired them to 10psi, going to release all the air)
Eibach anti-sway bar
eBay adjustable panhard bar
Cut out the bumpstop brackets
Wheels/Tire:
20" snowflake replicas
275/45r20 (went small to make sure nothing rubbed when I finally lowered it, will be getting bigger tires at the next tire change)
So far suspension float and body roll is massively improved and drives way better, even without the alignment.
(Ignore the dent behind the tire, blew a stocker and that's what the result was)
tytotheler92
Model/Year/2x/4x/AWD:
- 2001 Tahoe 2wd
Advertised drop:
- 2/4
Fender height front/rear:
-Unknown, will update.
Front:
- LCA's : Stock
- UCA's : Stock
- Spindles : Belltech
- Sway Bar : Stock
- Tie Rods : Stock
- T-bars : Stock
- T-bar keys : Decranked
- Shocks : Belltech Street Performance
- Steering : Stock
Rear:
- UTA : Stock
- LTA : Stock
- Springs : Belltech Pro Coils
- Panhard : Stock
- Sway Bar : Stock
- Air Assist : Airlift 60742
Wheels & Tires:
- Wheels : 18" 2019+ RST
- Tires : Michelin 265 65 18
Considered upgrades:
Alignment shop told me to get f*cked, I need to find another place. They did toe it, but my camber is quite negative. (Wouldn't give me a printout) Need to do free travel mod and get it aligned correctly/figure out control arms if needed.
Brief impressions of setup:
Not a bad ride overall, rear bottoms sometimes. Front feels great, and it handles so much better.
DadsToy
South Carolina
- 2001 Tahoe 2wd
Advertised drop:
- 2/4
Front:
- LCA's : Stock
- UCA's : Stock
- Sway Bar : Stock
- Tie Rods : Stock
- T-bars : Stock
- Steering : Stock
Rear:
- UTA : Stock
- LTA : Stock
- Panhard : Stock
- Sway Bar : Stock
Wheels & Tires:
I have the Crown springs on my unit. They seem to be a little soft and bounce over having the stocks installed. Was concerning the Belltech Coils. But wanted to know if you have any bounce with the springs you installed.
tytotheler92
They are stiff, I like them.
hardluck13
Figured I’d post. I never do and have been on here for like 11 years or something. I posted a couple weeks ago in exterior looking for help with headlights. Didn’t get much of a response. Long story short. The town I’m from has a bunch of aftermarket companies and I’ve gone to school and or have grown up with just about all (Whipple, McGaughy, Belltech, Speed Engineering, Full Throttle, Stone Fab, Western Chassis) to name a few. So me and my boys have been doing SEMA and show trucks since the 90’s. This Tahoe was bought new by me with the intention to make it a SEMA project. We ended up going a different direction and did a different new truck. So this Tahoe just sat for years. I let my buddies grandma drive it. It now has around just under 50k miles. I saw it sitting out at my shop and decided to start messing with it.
- 2005 Tahoe LT
Advertised drop:
- low / Tony’s 6” springs
- have never measured
Front:
- LCA's : Custom tubular Stone Fab Coilover Kit
- UCA's : Custom tubular Stone Fab Coilover Kit
- Spindles : Stock
- Sway Bar : Belltech
- Tie Rods : Custom hiem joint Stone Fab Coilover Kit
- T-bars : None
- T-bar keys : None
- Shocks : QA1 double adjustable Coilover
- Steering : New center section, HD hooked to Hiems
Rear:
- UTA : Spohn Adjustable with Del-Sphere
- LTA : Spohn Adjustable with Del-Sphere
- Springs : NorCal 6”
- Panhard : Spohn Adjustable with Del-Sphere
- Sway Bar : Belltech along with the offset dog bones
- Shocks : QA1 dual adjustable
- Air Assist : None
Wheels & Tires:
- Wheels : 22" Snowflakes
- Tires : Nitto 275/40R22
- Nope. I have billets floating everywhere in my shop. I’ve put so many sets on and for some reason keep going back to the wheels on it. Did a bunch of motor / performance. Building (2) 2 door 2wd right now so prob just mess with those and some of my other trucks.
Great kit rides great. Never had any bumpsteer. Handles like on rails (for a brick).
I need to update the pics. Rear appliqué are SS smooth painted, the hatch is the other type with no handle or plastic on top and it has SS painted smooth wiper cowl. Still need help with headlights.
Little update to mine. I don’t think I have ever listed engine mods or inside mods. truck has 60K on miles. Has heads, Holley high rise manifold, 103 TB, stage 4 cam, complete new valve train, long tube headers, no cats, custom 3” stainless exhaust with x pipe, Corsa tips, Volant CAI, I’m sure I’m missing stuff. With all that said here’s how it looks now……
That sux. What happened? Gonna fix it or part it out? I hope you can fix it.
Bjbmacon
What size crown springs do you have? I was looking at there kits? Do they really drop to what the specs say?
DadsToy
South Carolina
I have the 2/3 drop kit. Front spindles and rear springs. Yes it did drop it 2/3 inches. It measures even height all around. It's just the rear springs are too soft for my taste. Looking at the Beltech springs. Might be a little stiffer. Even with the air bags it still has a little bounce. I installed new MonoMax shocks which got rid of my death wobble. I'll install 20" rims and that should fill in the gap in the wheel wells. But over all it looks great. I didn't want to drop it too low, cause I want to tow a camper.
BADRIDES
If you didnt tell us it was lowered I wouldnt have known. Which kit did you use?
Bjbmacon
I have a set of 24x10 on mine w/ a 275/35 and I want it to sit almost on the tire.
DadsToy
South Carolina
Then I would go lower on the kit. I kind of wish I went lower. But doing baby steps before I slam it to the ground. If I had the money and budget. I would have done bags all around. Maybe some day I'll win the lottery.
IndyStreetRacer
- 2003 Yukon SLE 2WD
Advertised drop:
- 2"/3"
-Unknown
Front:
- LCA's : stock"
- UCA's : stock
- Spindles : BellTech 2"
- Sway Bar : stock
- Tie Rods : stock
- T-bars : stock
- T-bar keys : stock
- Shocks : BellTech Nitro Trash
- Steering : stock
Rear:
- UTA : stock
- LTA : stock
- Springs : BellTech 3"
- Panhard : stock
- Sway Bar : stock
- Air Assist : None
Wheels & Tires:
- Wheels : 20" Denali's
- Tires : Kumho 275/50/20's
- I have the Spohn Rear Adjustable Upper and Lower arms and Panhard bar that are not installed yet.
Overall, the ride sucks but I like the Yukon. Smooth roads are fine, but anything with bumps really stinks. I'm thinking of changing the shocks to something else. It now squats some, so the front needs to come down to level it out. I have a brand new set of TBSS 22" Silver Reps I'd like to put on, but don't want to lose more ride quality with less sidewall, so I'll stay with the 20's for the moment.
Glidin
- 2005 Tahoe LT
Advertised drop:
Front:
- Spindles : Stock
- T-bars : None
- T-bar keys : None
Rear:
- Air Assist : None
Wheels & Tires:
What are those taillights off of?
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
- 2005 Tahoe LT
Advertised drop:
Front:
- Spindles : Stock
- T-bars : None
- T-bar keys : None
Rear:
- Air Assist : None
Wheels & Tires:
Damn that looks good!
In-com-plete
Model/Year:
- 2005 2WD Escalade - 5.3
Advertised drop:
- 3"/4"
Actual drop:
- 3.25" / 3.5"
Fender height:
- 31" & 31.5" Front
- 31.5" & 32.5" Rear
Front:
- LCA's : stock
- UCA's : stock
- Spindles : MaxTrac 2"
- Sway Bar : stock
- Tie Rods : stock
- T-bars : stock
- Keys : 1" Un-cranked as much as I could
- Shocks : stock
- Steering : stock
Rear:
- UTA : stock
- LTA : stock
- Springs : MaxTrac 4"
- Panhard : stock
- Sway Bar : stock
- Shocks : Stock Air (blown)
- Air Assist : Dead stock compressor
Wheels & Tires:
- Wheels : 18" GM Gloss Black OEM
- Tires : Nitto NT421Q 265/65 R18
Storytime:
So I got this thing pretty cheap a year ago. Had 192k but was a grand cheaper and 10 times cleaner than any Tahoe or Yukon in a 75 mile radius of me. I immediately lowered it on the cheap, knowing I'd "clean it up" in the future. Present day is the future.
So I've had rear BellTech SP to replace the blown rear stock air shocks. But was going to install them after I ordered the DJM end links & rear control arm relocation kit. I should have spent the $200 on this a year ago. That's all I left out when I dropped it. Or so I thought.
While trying to make sure my MaxTrac shock extension will fit with the DJM stuff, I discover the Spohn control arms. Which led me to the Spohn Panhard bar. Which might be a must to get rid of this things Chevy lean. Any thoughts from anyone?
Also, I'm attaching a pic of this dirty AF thing. I guess I'm old as I like the 18's with the bigger tires. Both the look and the ride. Reminds me of high school. Heating and/or cutting springs on our mini's riding on stock wheels and tires. But I'm glad I went with MaxTrac. The springs are a little soft and barely settled any. With the apindles and keys de-cranked, they were just barely able to align it.
JamesinAbilene
