Geotrash
Dave
Richmond, VA
noise is usually the 1st indication, should be pretty much silent when spinning the wheel while off the ground, next thing would be movement @ 12 & 6, abs errors
Yeah, know that these are the usual symptoms but was just wondering if his actually was exhibiting any of them. It's reassuring to know that it was.
You wanna unload it?
Not sure yet! I'm still trying to sort out my drop. I'm actually looking into reinstalling my old and squishy struts for ride quality but bolting them under the control arm to maintain the drop. Honestly, you'll have your stuff finished before I have time to mess with mine.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
No prob pal! :)
I have a feeling I am being setup. What's the term? Careful what you wish for? He has been walking both sides of the fence lately in his posts.
Lately? You obviously haven't spent enough time on any construction sites.
Might ask me for a reach around or somethong...
Definitely somethong.
St. Louis
Did absolutely nothing to it today. Too damn hot out.
Current temp in the shade
Just Fishing
Can't fix stupid
Utah
Planning to do some work on the wife's car this weekend.
Ac work, needs a new condenser.
Found a slow leak on the upper passenger side.
I missed this leak last year when i topped off the refrigerant.
I just happened to see some oil wet when pushing a air deflector back into position and decided i better find the source.
I found an aftermarket ac condenser had been installed after some minor front end damage was repaired per the prior/original owner.
It was done by the gm dealer, yet they used an aftermarket upper bumper bracket and ac condenser...
The work looks good otherwise, can't even tell it was hit.
There are a few other things I would like to replace while i have the ac system open.
But they are against the firewall.
And I'm not wanting to fk with that unless i have the intake off.
And if i did that, then it's time to update the valve cover gasket to address aome pcv issues.
And spark plugs + wires while I'm there...
So yeah, probably just going with the ac condenser + oil balance for now.
Something to think about later when i do the actual sparkplugs this fall/winter.
Drewphil
