Thin gray line tahoe build
T
thingraylinetah
Crossville Tennessee
Okay so I went to install a new digital climate control in my tahoe. The main bluev plug plugs into the socket on the module labeled "blue" the other port is listed as "gray" my other wire is black and won't plug into the port labeled gray. How do I fix this?
You sure you have the correct head unit?
That's weird. Are the part numbers the same? How many prongs in the unit compared to the plug?
Buy the correct control. Get the PN off the back of yours and look for the same part. Never trust EBay’s compatibility charts. There’s too many different RPO options on these trucks.
T
thingraylinetah
Cast iron block
Stage 3 cam
Polished crank
706 heads reworked for better flow
Ls6 blue beehive springs
BRIAN TOOLEY racing push rods
Brian Tooley racing lifters
BTR timing chain kit
Bronze trunions
That's all I can think of right now.
Flat top pistons.
Bigger injectors than stock
King race bearings
I'll do some more updates if they become available.
T
thingraylinetah
Cast iron block
Stage 3 cam
Polished crank
Bronze trunions
Flat top pistons.
King race bearings
I'm thinking of doing a dynomax ultraflow muffler.
T
thingraylinetah
Anyone have any experience with the dynomax ultra flow? I've heard they give a decent hp gain, performance sound outside car with little to no drone inside the hoe. I've watched alot of you tube videos and apparently had alot of happy users. I really want the magnaflow but for the complete bolt on its like 800. The dynomax is around the 400.00 range
