Been doing well bud. Thanks for asking. Yourself?
Looks like I haven’t missed too much as of late. Anything I need to be caught up on in the past six months? Ha!
Good ole Asheville. I used to pass through Winston Salem area on my way to/from Michigan and NC. I took the Asheville route one time in the winter and decided that mountain range was meant for skiing and hiking, not driving. Granted it’s the same mountains going the other route, just not nearly as steep.
Are you running any anti-sway stabilizer bars between your trailer and the hitch?
I suspect you've been up to some secret squirrel stuff:patriot::secret:
"Cash only" because I know someone will want to trade some ****** (apparently you can't type "hairoin")or fentanyl for them. Shit is so common around here.
Although I should have said I would trade for pressure-treated deck boards.
My aunt fell and fractured three ribs. The local pharmacy cannot fill the fentanyl script until next week, so where do you live again? LOL
Just Fishing
Can't fix stupid
Utah
here i am looking for a set of wheels for the tahoe.
Then i see these for $60 for all 4
Me,
Then I see they are for a 2500
:rage:
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Guys, I am shopping for rear shocks and I see many notes about a ZW7 code. I do have that code on my RPO label. But I just have regular looking shocks. I looked up that code and it says premium ride with Nivomat self leveling?? I see no trace of that under my truck. No hoses or pump or anything. Does that mean the PO removed all that stuff???
I didn't think they put the Nivomat's on the gmt900's but if they are the rear shocks are much larger looking than normal and they are expensive.
mountie
I have nivomats..... They are configured within the shock it's self.
( Why they are pricey)
89Suburban
SE PA
Can I just put regular shocks on it instead??
89Suburban
SE PA
It's been done.... I am sure there are threads to show how...
it may require a bit more than 2 bolts to R&R a shock.... maybe coil springs too?
Someone will chime in.....
I just ordered a 2" rear drop kit so the springs are getting swapped out anyway.
To be clear, the Nivomats are self-contained and do not have wires, hoses, or other connections (other than the physical mounts). Your '07 doesn't have Nivomats.
89Suburban
SE PA
Here is my RPO. SO I can just order regular shocks even though I have that code on it?
ASG-MikeS
