Guys I need help figuring out this engine rattle
Today I am going to disable my fuel pump and turn the engine with the starter to see if I can replicate the sound.
Easy: Just hold the throttle pedal to the floor while cranking and it'll keep the injectors and spark plugs from firing.
I am hoping that pulling the heads I will find some problems with the lifters, push rods, or valvetrain.
Hoping for anything minimal.
if you have any other useful advice that would be great.
Use a large, blunt punch and hammer to give the heads of the exhaust manifold bolts a few good knocks to help shock 'em loose to reduce the chance of breaking them. Put a socket around them and beat on that a few times to shock the surrounding iron of the manifold flange. If you have a small, relatively weak impact gun (or turn your air pressure way down), a few hits towards tightening before loosening and maybe repeating a few times back and forth can help. No need to rush this part cuz you'll surely negate any time saved when you have to fight broken bolts.
TollKeeper
Brighton, CO
Having just gone thru collapsed and exploded lifter, and a pushrod in the shape a letter Z. Just start in the valve cover, both sides. Relative easy, and you dont even have to pull the intake (at least on my LH6 I didnt).
Go in there and look for loose rockers, or even a pushrod sitting off to one side (both of these I found on cylinder #1 intake).
The baffling question is, if it was a pushrod, lifter, or stripped rocker, you would have a MIL light for a misfire on a cylinder. You didnt mention this that I saw.
Dustin Jackson
Dustin Jackson
@iamdub Thank you for that advice!
@TollKeeper I do have a code for cylinder 6 misfire, I don't know if I mentioned it in this thread or not but I will be focusing my inspection on the passenger side for sure.
really?! This would make top end soak easier
I speaketh the trutheth. No need to pull fuses, unplug stuff, etc. It's a GM feature called "Clear Flood Mode". Prior to my engine refresh, I used to use it all the time to prime my oil system to help a ticking lifter when starting my Tahoe after it sat for a week or three. You hold the pedal to the floor (there's a specified minimum throttle- like 80% or something, but flooring it is easiest) and turn the key. You can hold it but it'll automatically stop cranking the starter after ten seconds to let it cool.
Dustin Jackson
Dustin Jackson
I was not able to replicate the sound by just turning the engine with the starter.
I can vouch, pedal to the floor while cranking won’t start it.
FasterBass
Well goll-e thanks for the info!
Dustin Jackson
Dustin Jackson
Got the intake manifold and valve cover off on the passenger side today. I wasn't able to find anything wrong, I took the pushrods for #6 out and they all look nice and straight. The rockers for #6 look the same as the rest of them. I am a little confused, I thought I would see some evidence of damage by now. Tomorrow I will pull the head and hopefully see something wrong.
Here are a couple videos I took today:
And here is a clip of my lady turning the motor over for me. As you can see it appears that the valves for #6 work just fine, How do you disable the fuel pump? I pulled fuse #20 and the fuel pump relay but as you can see the fuel pump still works..
What are your guys thoughts here?
Did your lady floor the accelerator pedal while cranking, to use clear flood mode? (Or as Dad would have called it, "the footfeed." ;) )
Dustin Jackson
Dustin Jackson
@Fless I told her to but I think that just disables the injectors, but doesn’t turn the fuel pump off.
Some rockers are gonna be easy to slide side-to-side and some will be locked up depending on where they're at in the cycle. If you turn the crank enough, you'll find that those locked ones will now wiggle and the others will be locked up.
Oof. Yeah, I didn't mean to try the clear flood mode with the manifold off. I thought you were just gonna pop the valve covers off and crank it. These things with the fuel pump being controlled by an FSCM means removing the fuse labeled "FUEL PUMP" does nothing. Some don't even have that fuse or the relay in place. Try removing the one labeled "FSCM". I think it's #21.
Dustin Jackson
Dustin Jackson
@iamdub Should I be concerned I haven't found evidence of damage up to this point? Is it still worth it to pull the head?
Checked under the other cover yet? I know you said it sounded loudest on the passenger side. But, sound can travel through a block. Also, the lifter might not be collapsed and "just" turned in the bore. It'd still move the rockers and appear normal.
Unfortunately, it might not even be a lifter or even in the valvetrain. You might have a spun bearing. Either way, you're gonna have to dive deeper and the engine will almost certainly need to come out. The heads being off will only make this easier. After checking under the other cover, you have nothing to lose by pulling the heads. It's pretty much the next step in diagnostics.
Wait- have you checked your spark plugs to make sure they're all good and fully tightened? Although, it does sound lifterish or spun bearingish. Also, loose converter-to-flex plate bolts or a cracked flex plate can rattle. But, this wouldn't explain the misfire code.
Dustin Jackson
Dustin Jackson
@iamdub I haven't checked the other side yet because the check engine light said it was a cylinder 6 so I only checked the passenger side for now. Tomorrow I will try to make some progress but it is fathers day
Dustin Jackson
Dustin Jackson
Well I got the head off today and here is what I found:
Dustin Jackson
Dustin Jackson
At least you found your culprit. I suspect thats just carbon bits down in the cylinder.
Should be a cam and lifters and run it repair.
Lots of junk for sure, all the metal seemed in condition
TollKeeper
Brighton, CO
Yeap.. Wiped cam, bad lifter tray, bad lifter, pushrods should still be good thou.
Good time to do a AFM/DOD delete if you want.
X-ray Nerd
