Ticking noise. Lifters?
rn4l21
This ticking just started on my ‘05 Tahoe. Doesn’t really sound as loud on a cold start. Hoping it’s not lifters or a rod knock. Any ideas what it could be?
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
You can tell the difference between a rod knock and a lifter tap by the speed and sound of it.
R
rn4l21
Sounds like lifter tick to me but that metallic sound at the end of each tick leads me to believe you have a loose rocker arm for whatever reason.
I was hoping it wasn’t that smh. It’s only got about 185K on it. Runs and idles so smooth. No CEL, no bad idle. I guess it’s time to let her go.
MassHoe04
Western MA
Don't throw out the baby with the bath water before knowing what it is or how much time/money it would cost.
Before assuming the worst, I would also want to rule out 100% anything to do with moving parts up front. I would see if the noise stops, if the serpentine belt is off for a quick check.
Maybe you'll be REALLY lucky and find something stupid like bad alternator bearing making that tick. Wouldn't cost anything to check. I would want to be sure nothing like that was the cause, before jumping to the next possible worst case.
Could be just a bent (or worn) lifter and/or loose rocker. If you end up with something like that, you might get off relatively cheap (no replacement truck or replacement engine needed) and be as good as new when done.
Just trying to be an optimist today... Hope for the best and try not to jump the gun on dumping the truck. If you have to, you have to. Just see what exactly you are up against first.
wjburken
Eastern Iowa
I agree with @MassHoe04. It’s a little early to call time of death on this thing.
Take it step by step checking the easy stuff first. Quick question before I go any further. What is your oil pressure showing on the dash?
It costs nothing to take the serpentine belt off and to see if the noise goes away as mentioned. If it does, then focus on the spinning parts in front of the motor. If it’s still there, then go to the next step and pull the valve covers and check your rocker arms and push rods. If that all looks good, then move on to checking the lifters. If you can get a good idea of where the sound is coming from, that can help as well. Get a long screw driver or a mechanics stethoscope and see if you can narrow it down, at least to a side of the motor. That will give you a better starting point.
R
rn4l21
It’s pegged at 80 so I’m not sure if that’s the actual pressure or if the oil pressure sending unit is bad.
wjburken
Eastern Iowa
It’s pegged at 80 so I’m not sure if that’s the actual pressure or if the oil pressure sending unit is bad.View attachment 364430
Definitely seems suspicious.
Have you checked your oil level? When was your last oil change filter change? Might want to get a analog gauge on there and see what the actual pressure is.
R
rn4l21
Yeah. Oil level is good and clean. I had an oil change about 300 or so miles ago. I’ll have to try out an analog gauge.
wjburken
Eastern Iowa
My guess is the sensor is wonky, but always good to make sure. Did this whole noise thing start after the oil change?
What type of oil and filter was used? Did you do it or have it done?
Not saying it’s the cause of your ticking sound, but one of the first things I do when trouble shooting is asking “What’s different now?” and an oil change 300 miles ago is one data point that’s changed. I don’t want to shift all focus to this as it may be completely unrelated, but it may not be.
I would still take the serpentine belt off and run the truck to see if you still have the sound.
R
rn4l21
I did it myself and just did the standard 5W-30 Valvoline with an AC Delco filter. I just noticed it about a week or so ago. It doesn’t really happen on a cold start which I find weird but if I turn it off and turn it right back on, it starts ticking again.
What does the oil pressure gauge read with the key to 'run' and engine off (KOEO)?
You might also see what the oil pressure PID reads with a scanner, KOEO, and with the truck running.
R
rn4l21
It reads 0 when it’s in the run position. I’ll have to try a scanner tomorrow.
MassHoe04
Western MA
Check the connector on the oil pressure sensor.
According item #2 to the post below, a gauge pegged to the max. could be result of a disconnected sensor.
Could also be a broken wire or bad connector...
Start there, with an inspection at the connector and wires to it.
This was posted on ChevyForum.com. Maybe it will help you figure things out on whether it is your gauge or the sensor...
(1) Check the oil level and correct as necessary. Turn the ignition switch on, but do not start the engine.
(2) Disconnect the sensor lead at the sensor. The gauge should read full scale.
(3) Ground the connector. The gauge should read at the bottom of the scale.
(4) If the gauge functions properly, replace the sensor.
rockola1971
Indiana (formerly IL)
Not the end of the world unless its caused by low oil pressure. Not at all uncommon at all for the LS engines to get a little lifter tick with your mileage. Sometimes its nothing real serious at all and ends up just being a sticky lifter which can be be fixed by a quart of tranny fluid ran through the engine immediately before an oil change in the driveway. The tranny fluid frees sticky lifters. DO NOT DRIVE WITH TRANNY FLUID IN YOUR OIL.
05YukonXL
South Carolina
Any resolutions? I just got my 2014 Suburban back from body shop and got a 'Check Engine' light. Mechanic read error as misfire, at low RPMs on Cylinder 4. Ruled out plugs and coils. Did oil/filter change. But no time to diagnose further, I towed a trailer 200 miles (75MPH average) and a clicking noise revealed itself upon arrival. And noticed the check engine light went away. The clicking, initially sounded like bearing on alternator but... then thought maybe lifter issues on the #4? The next day, (no trailer) the clicking stuck around (did 30 miles). Third day no clicking, check engine light back. Now to further diagnose...
rockola1971
At NIGHT open hood, start engine, look for flashing show around coils or spark plugs and you have located your bad spark plug wire or coil. The clicking you hear might be the spark jumping to the nearest metal which is ground which would also cause a misfire. Dont even think about sticking your fingers down in there while the engine is running or you might become ground and get the bejesus knocked out of you.
R
rn4l21
Yes. It ended up being an exhaust manifold leak. The bolts were broken. Never even crossed my mind to check :smh:
Escalade2007
