davidavidd
Hi TY forum members happy new year from Colombia, long story below:
I have a 2007 Tahoe, stock 5.3 engine (I've only added an oil catch can and transmission radiator), 180,000 miles with all the maintenance routines.
Four days ago I did a little 300 mile round trip (mixed road between flat and mountains but nothing out of the ordinary). When I was about to return home I stopped for gasoline and out of habit I opened the hood and found drops of oil on the Vortec engine cover (near the clean side of the pcv system there was also a lot of oil and almost the entire air intake tube was covered on the front and bottom side).
The hoses to the right side of the radiator also had oil in it and the lower engine splash shield had some large stains. My first impression was that the transmission radiator installation had failed but upon checking it was engine oil, not transmission oil. With the engine off and then on, I continue checking but I can't see any oil leaking from any hose and it shouldn't because the engine oil doesn't circulate there. The main engine gaskets looks dry (valve covers, heads and oil valley), it is a real mystery for me to know where this oil comes from since the level was only half a quarter below the normal level and I was able to finish the trip without observing new oil stains.
I don't have any lights on on the dash, no check engine, no overheat alerts, the coolant looks normal, and the truck continues running solid. Someone has a clue since obviously it is not something normal to happen. I attach photos so you can observe.
PD: sorry for my bad english and please ignore the temporal heater bypass. The truck does not have an oil cooler installed.
