StrkAliteN
Damn! Those are awesome…
Loho’s headlights
What is a Loho headlight ?
I am guessing it is some LED replacement lamp / bulb for the standard factory headlights ?
My '07 SLT still has all the original front factory lamps installed ( headlights - turn signals etc etc )
I am aware that some crazy bumper removal and other hassles may be required to change them out when / if any fail.
So I am planning to replace all upfront with LED lites at once so I never have to deal with ever again.
Geoffsfas10
St. Louis
even with the LED you still need to pull the bumper cover to get the clearance needed to install the lights. also not all LEDs will clear the radiator support. and the DRL sockets tend to burn thru LEDs very often.
Bill 1960
Testing the Limits
I’ve had a leaking seal at the output shaft of the front diff since I bought it. Driver’s side. How hard is that seal to replace? Can it be done in place?
That is a fairly easy repair. You will need to unbolt the axle from the flange and swing the axle out of the way. Then that stub shaft with the flange pulls out. I would use a GM seal on that and take a look at the bearing that shaft rides in when you have the seal out.
EDIT: I removed some incorrect information.
Finally got around to this today, went fairly easily just as George (and others) said. The only difficult part is pulling the drive flange and stub shaft out of the diff. That takes a LOT of force. I used an assortment of wedges behind it and running bolts through the flange to persuade it. No room for a slide hammer with the spindle and everything else in place.
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
Tossed a new battery in it today. Guessing the Bosch in it was maybe from 2018??? It’s not marked in any way. Bought a Continental battery from my trusted local parts guys for $136 and some change. Research says these guys are partnered with Stryten Manufacturing. Stryten is operating the old Exide plant in Salina KS.
Edited to remove excess information.
Edited: Found an SDS forn the battery by JCI.
CaptainAmerica1
Arlington TX
Some links below:
Our Brand Family | Continental Batteries
Continental Battery has a vast network of over 90+ distribution centers and 25,000+ retail sellers. Click to learn more about our brand offerings.
www.continentalbatterycompany.com
Stryten Energy and Continental Battery Company Partner to Meet the Growing Energy Storage Needs of the U.S. Automotive Aftermarket | Stryten Energy and Continental Battery Company Partner to Meet the Growing Energy Storage Needs of the U.S. | Contine
Stryten Energy and Continental Battery Company Partner to Meet the Growing Energy Storage Needs of the U.S. Automotive Aftermarket | Stryten Energy LLC, an energy storage solutions provider, today announced it has entered into an agreement with Continental Battery Company to supply batteries for...
www.continentalbattery.com
Transportation
Stryten Manufacturing is a leading battery manufacturer, building power solutions for the Transportation and Industrial markets.
View attachment 359173 www.stryten.com
You work for them?
well had to get them for the Yukon, they work awesome on the Silverado
BlackHoe13
Were you getting a misfire cel on cyl 4?
No! I couldn’t believe it when I pulled that pushrod out. It has has a faint lifter tap since I bought it nearly 2 years ago. The only thing I noticed was complete lack of power. I just assumed it was the gearing (3.08). Really expecting the cam and all the extras to wake this hoe up.
ASG-MikeS
