6L80 Sonnax ZIP Kit, Pressure Switch rebuild, remote filter install, and fluid flush in 2013 Escalade ESV (Pic heavy)
skpyle
skpyle
Senior Member
Next step was to install the Sonnax Actuator Feed Limit Valve. Again, valve held in place by a retainer. This time, the spring was on the outside of the valve, up against the retainer. Had to be careful to hold both 'sides' of the spring when pushing in to free the retainer. After I got my old valve out, I looked at the instructions, and went looking for the new valve. In the kit bag, I found the sleeve and the spring, but no valve. I had been gypped!!! No. I am just an idiot. The valve was inside the sleeve...
I installed the sleeve, being careful to orient the grooves to the inside, followed by the valve, with the spring seat to the outside, and then the spring. And then again fight the spring to install the retainer.
Actuator feed limit valve kit. Note: I removed the valve from the sleeve for the photo. Because I was dumb and couldn't find it earlier.
Actuator feed limit valve, spring peeking out behind the retainer.
Spring and retainer.
OE actuator feed limit valve and spring.
Looking at the sleeve through the valve body, you can see the one of the grooves at the top.
skpyle
skpyle
Senior Member
Next step was to install the Sonnax Clutch Select Valve Spring kit. However...I did NOT do this. Because the ZIP kit instructions told me not to. This spring kit is for mid-'10 and earlier 6L80's with the earlier separator plate. My 2013 6L80 had the updated separator plate and revised springs. I did, however, install the O-ringed end plugs. So, nothing to see, no photos. These plugs installed just like the four end plugs I installed earlier.
Next step was to install the Sonnax Compensator Feed Regulator Valve. Like everything else, retainer, spring, and valve. Installed the new sleeve, valve, and spring. Oriented the sleeve so the chamfered slot end faced inward.
Compensator feed regulator valve kit.
OE spring after the retainer was removed.
OE compensator feed regulator valve and spring.
skpyle
skpyle
Senior Member
Next step was to install the Sonnax TCC Regulator Valve kit. The instructions stressed assembling and orienting the new valve components correctly as per the diagram.
Screenshot of TCC regulator valve kit instructions showing assembly and orientation.
Same as before, remove retainer, end plug, valve assembly, and spring. Install new components in the correct order and orientation, reinstall the retainer.
OE TCC regulator valve assembly.
Sonnax TCC regulator valve assembly.
skpyle
skpyle
Senior Member
Random interjection: earlier, when I was talking about removing the valve body screws, I could not find any decent photos of the EP10 Torx Plus headed screws. The Sonnax ZIP kit instructions had a good image of them, and the socket.
Screenshot of Sonnax ZIP kit instructions referring to the valve body to transmission case securing bolts with the EP10 Torx Plus head and the factory GM tool to remove/install them.
skpyle
skpyle
Senior Member
Next step was to install the Sonnax Checkballs. From what I understand, the OE plastic checkballs can deform and get hung up on the separator plate. Sonnax checkballs are 'imidized' plastic. They are supposed to wear better and resist deformation. I threw away the 7 OE checkballs from the valve body, and installed the Sonnax checkballs in their place. Note: pay attention to how many check balls go into your valve body. Most will take 7, however, there are some applications that will take the 8th one.
Screenshot of ZIP kit instructions showing locations of 7 checkballs.
Sonnax 'imidized' plastic checkball.
Sonnax checkballs in upper valve body half.
Close up of checkballs.
skpyle
skpyle
Senior Member
1986.5 Porsche 928S
My Red Witch
5.0L DOHC water cooled V-8
For relevancy to this thread, here is the Porsche A28.07/Mercedes 722.3 4spd automatic transmission with pan removed.
I have several threads going on the Red Witch over on Rennlist.com.
Geotrash
Dave
Richmond, VA
1986.5 Porsche 928S
My Red Witch
Beautiful. I have a thing for transmissions as well. I present you with the weakest link of the ZF 5HP24. The A-clutch drum failure triggered by a worn pressure regulator in the valve body.
skpyle
skpyle
Senior Member
With all of the necessary parts installed/replaced in the valve body halves, next step was to reassemble the halves and separator plate. I wiped both valve body halves and the separator down with lint free rags, but I did not try to get them completely dry. I just removed the still liquid ATF from the separator plate faces and the sealing surfaces on the valve body halves, if that makes any sense.
I installed and tightened the bolts to hold the valve body halves together by referencing Step 1-f, and figure 8. As per the instructions, I torqued them to 71 inch/pounds in the described sequence. Me being OCD, I did it in two rounds. 40 inch/pounds first round, 71 inch/pounds second round.
Torquing bolts to 40 inch/pounds for the first round. Note figure 8 and the torque sequence.
Next step was to install the Sonnax Center Support Seal Kit. This is kind of a misnomer, as it actually isn't a seal kit. It is a series of steel bushings that positively locate and support the OE seal stack from the valve body to the transmission casing.
Sonnax Center Support Seal kit. Note the bushings are different. Some have grooves, and some don't. As well, some springs are shorter than others. The instructions specify what goes where.
The bushings without the grooves are tapped into the four holes in the top approximate center of the valve body. They took a bit more force to tap in than I expected. I ended up using a brass block on the bushing and hammering on the block. The shoulder on each bushing must be flush against the valve body machined surface. All four went in just fine.
Bushings installed in the valve body.
Metal cup end of the OE seal stack goes over these bushings.
OE seal stack pushed onto the steel support bushings.
NOTE: this is a new OE seal stack. It came in the GM 24236934 Plate Kit, Control Solenoid Valve Filter. As well, the other valve body to transmission case seal set was included.
skpyle
skpyle
Senior Member
This is one of the main reasons I went through all the effort to pull the valve body out of my 6L80 transmission: to rebuild the pressure switches. Mine worked fine, but I wanted to go ahead and rebuild them preemptively.
The round port with the sorta orangish center is one of the pressure switches. The outer part is the seal, and the inner part is the disc/diaphragm. The seals and diaphragms are the failure items. Diaphragms more so. From what I understand, the diaphragms break/rip/tear/etc... over time and stop actuating the switch below. Age and dirty ATF add to the wear. In some cases, the seals deteriorate and fail as well.
Note the discolored spot on the disc. This is light sludge from the ATF.
The seal and disc removed. NOTE: this disc got deformed as part of the removal process. It is well documented in the Sonnax pressure switch rebuild instructions.
Now, I do take umbrage at part of the Sonnax video for rebuilding the pressure switches: Under the disc, is the white plastic actuator for the pressure switch underneath. In the video, the technician effortlessly removes the actuator with a pick. Yeah. BS. I could not get any of the actuators to come out with a pick for love nor money.
So...I got creative. I used a little vacuum cap for suction. I squeezed the cap pressed into the actuator. The little bit of suction generated was enough to hold onto the actuator and pull it out.
The white plastic actuator for the pressure switch. That did NOT come out effortlessly with a pick.
My solution to the problem: suction with a vacuum cap. It was a bit finicky to get the cap on the actuator and squeeze it so the suction held, but it worked.
Actuator removed.
skpyle
skpyle
Senior Member
Scalloped underside of the actuator.
The actual pressure switches themselves, under the seal, disc, and actuator.
The Sonnax pressure switch rebuild kit and tools set I bought off ebay. You really want the tool kit. Cough up the $35 or so it costs. Listen, I don't care how much of a Billy Bad-A$$ you think you are, getting the seals installed without killing them without the special tool is going to be soul killing. Buy the tool kit.
This kit I bought off ebay had 5 seals and 5 discs. 4 needed plus 1 for screw ups. I ended up later buying an additional 5 deals and discs alone to have on hand for 75,000 miles from now, or so.
New discs and seals installed in the pressure switches.
There is alot that happened to get to this photo. As per the instructions, I blew out the pressure switches with 30PSI air to clear any debris. Then, after watching the video around 30 times, and having it playing as I did the work, I started installing the discs and seals.
My observations: The instructions are quite detailed and good for installing the dics and seals. It calls out all the little details. However, the video really brought it together. Seeing the technician use the tools made it that much clearer for me.
However...it was still nerve wracking!!! Granted, I had one spare. But that just meant I only had one chance to screw up and not be doomed.
My main concern was the fact that the discs had to be deformed a bit to fully install them. Once you have bent them into the inverted taco and slid one side into the bore, the other side sticks up and has to be forced down. The tool does this well, but I still had visions of crinkling or damaging the disc.
I got all four of them. In spite of myself.
Next...the seals. The instructions are good and the tool makes sense once you figure it out. However, make sure you firmly hold the outer part of the tool against the TECHM, and then more firmly push down the plunger. Don't stop pushing down on the plunger until the outer part of the tool pops up off the TECHM. Watch the video, it will make sense. I almost screwed up the first seal because I stopped pushing when it felt like the seal was in. The seal was close enough to being fully installed that I was able to massage it in place. There were curse words.
skpyle
skpyle
Senior Member
Next step after rebuilding of the pressure switches was replacement of the shift solenoid filter plate. I purchased a new GM 24236934 Plate Kit, Control Solenoid Valve Filter. Note: I researched this on gmpartsgiant.com. Beware, there are a couple of different versions of this filter plate. Make sure you get the one that applies to your particular 6L80.
Removing the old filter plate was a bit concerning. The Sonnax ZIP kit instructions recommend replacing this plate everytime the TECHM is removed from the valve body, because the seals take a set. The service manual warns to not break off any of the 4 locator tabs on the TECHM for the filter plate. Well...the TECHM is plastic, the tabs are plastic, the filter plate is plastic, and it is on there pretty tight.
I did not break any tabs, but was overly cautious in removing the filter plate. I used a combination of screwdrivers and picks to gently lever it up and off the tabs.
Reinstallation was gently pushing the new filter plate down onto the tabs.
Now, I did screw something up... The ZIP kit instructions say to inspect the shift solenoids and blow them out with 30PSI air. I got part of that right. I inspected the solenoids in the TECHM, and noted the had a little grey film of sludge on them. However, I got wrapped up in the pressure switch rebuild and forgot to blow out the solenoids with air. Grrr...
(EDIT: transmission shifts and works properly after all this work, so the solenoids are functioning properly.)
Shift solenoid filter plate, circled in green.
New GM shift solenoid filter plate. This kit also included the three seal stack sets, a couple of large O-rings, and new OE checkballs. I left the O-rings and checkballs in the bag, because I didn't use them.
Shift solenoids, circled in green.
Old filter plate at top, new filter plate at bottom. I compared them closely to make sure they were identical.
New filter plate installed on the TECHM.
skpyle
skpyle
Senior Member
Now that the TECHM was done, next step was to reassemble all the various parts back on the valve body. I followed the reassembly steps in the Sonnax ZIP kit instructions, paying attention to torque spec and sequence.
Valve body with the TECHM and position switch reinstalled.
Valve body with input/output speed sensors and harness reinstalled, as well as all three seal stacks.
Comparing old seal stacks that came out of the transmission with the new ones that came in the filter plate kit.
skpyle
skpyle
Senior Member
One more step before I could reinstall the completed valve body back into the transmission case. I had to install the other half of the Sonnax Center Seal Support kit. I installed the four steel bushings that were grooved into the transmission case. No brass block here, as the bushings sat in wells. I used an appropriately sized punch and reasonable hammer force. No problems.
Sonnax Center Support Seal kit. Bushings with the grooves go into the transmission case.
One bushing tapped in. You can see the holes at the bottom of the wells.
All bushings tapped in. That is not an optical illusion. The center two bushings sit higher than the outer two bushings.
It is difficult to see in this photo, but the outer two seals are taller than the inner seals. This matches how the center support bushings in the transmission case sit higher. As per the Sonnax instructions, the short 0.250" springs inside the outer two seals only. I held them in place with petroleum jelly. I then installed the seal stack in the transmission case, over the steel bushings. And hoped like h*ll the spring pressure didn't push the seals off before I got the valve body installed.
Seal stack installed in the transmission case.
skpyle
skpyle
Senior Member
Installing the valve body was a real treat...
I was concerned with aligning the bushings for the center seal stack on the valve body with the seal stack installed in the transmission case. Because I had to install the back of the valve body first to engage the electrical connector, then tilt the front of the valve body up. Also, don't forget to make sure the black plastic plunger on the position indicator switch lines up correctly the manual shift shaft lever. I got it the first try, though it was a bit nerve wracking. There is no way to see the seal to see if it went in. I just went by feel. IE the valve body felt flat against the transmission casing with no rocking. I started all six EP10 Torx Plus bolts and tightened them hand tight.
And then remembered the white latch for the electrical connector.
And it wouldn't latch. I tried pushing a touch harder. Bad idea, things started flexing.
I tried manipulating the latch back and forth. Side to side. Nothing.
I loosened the valve body mounting bolts and gently pushed the valve body towards the electrical connector.
Nope.
Electrical connector latch. Not latched.
So...I pulled the valve body back out. I did find that none of the center seals were deformed, so I did get it right on install.
Back on the work bench, I looked at the latch. I looked at the electrical connector on the TECHM. And found nothing wrong. I tried pushing the latch. It would not go.
I performed google-fu for valve body electrical connector. I watched videos. Only one had anything to do with the electrical connector, and it was for the plug outside the case. Which wasn't my problem. (Ominous foreboding music...)
Looking closer, there are two little metal 'fingers' at the bottom of the latch. I gently pushed the fingers towards the TECHM with a pick and pushed down on the latch.
CLICK. It latched.
This told me the electrical connector wasn't seated properly.
Hmmm...if the valve body can't move any closer to the connector (because of the center seal stack and the mounting bolts), then maybe the case electrical connector isn't right?
That thought scared the bejezzus out of me. I really don't like damaging things on my new toys. Especially ones I need to drive daily.
Back under the Escalade, I stuck my head up behind the transmission to look at the electrical connector on the outside of the case. I gently pulled on the cable to see if it was tight. And the whole thing came off and out of the transmission. And I deposited ***** matter into my undergarments.
After learning to breathe again, I remembered the useless youtube video I watched on the electrical connector that wasn't my problem. It discussed how the outer electrical connector was a twist lock type of connector. OK...
I reinstalled the valve body. I then gently pushed the electrical connector back into the transmission case and turned as I went. I turned and then fell into position. I gave it a little push and the off-white latch on the connector latched into the transmission case.
Back at the valve body, I pushed on the electrical connector white latch. It latched.
Electrical connector at the back of the transmission case. Note the off-white latch and the black lever sticking out to the right...
View of the electrical connector on the TECHM through the port in the transmission case from the outside. If you zoom in, you can just see the spiral grooves in the connector locking sleeve inside the port.
Electrical connector latch. Latched.
Finally. The valve body was completely reinstalled.
skpyle
skpyle
Senior Member
Next step, install the new transmission pan with the welded nut and drain plug.
I require a drain plug the automatic transmission pan of any vehicle I own. Whether it had one to begin with, or if I have to add one as I go.
My plan was to have my machinist weld a nut to the bottom of this pan while I was doing all of this transmission work. Yes, I know, I am dirt because I cannot weld. It is what it is.
For giggles, I looked up the price of a new transmission pan for the 6L80 in an Escalade.
GM 24222657, $15 on Rock Auto! $24 on Amazon!!! SOLD
I found a suitable drain plug, gasket, and nut. I drilled a hole in the pan in a location I felt suitable based upon google-fu. I have screwed this up in the past. This time I made sure just in case that the drain plug tip didn't protrude far into the transmission pan. I then delivered all of that to my machinist to be welded. We did the same thing to the pan on the Explorer's 4R70W.
A bit of philosophy. I have the nut welded to the outside of the pan so the most fluid will drain out. If the nut is on the inside, then you will still have the thickness of the nut level of ATF in the pan. Which can be a considerable amount. Ground clearance is not an issue with this pan, so I had plenty of room to put the nut and drain plug on the outside.
New pan, hole, nut, gasket, and drain plug.
Comparing old pan at left to new pan at the right.
Cleaned magnet and gasket go on the new pan. The old pan goes back into the box for the new pan and will be stored away for future use.
New transmission pan installed on the transmission.
skpyle
skpyle
Senior Member
Next step is to reinstall the exhaust. I put some high temp nickel antiseize on the exhaust manifold down pipe studs so I can do this again in the future.
I installed new manifold to down pipe seals before pushing the down pipes back up into place at the manifolds.
For the driver's side, it was a conical 'donut' seal that lightly pressed into the exhaust manifold outlet. GM 1503747.
For the passenger's side, it was a crush ring type seal that sat in a receiver groove in the top of the flange on the down pipe. GM 15077362. I had to install that one by Braille.
With the seals in place, I pushed the down pipes back up to the manifolds and started the six nuts by hand. I ran all six nuts down as far as I could by hand.
This time, I did not need the 15mm flare crows foot. I was able to get the 15mm deep well socket on all the nuts, though I needed the universal joint for a couple. Torqued all the nuts and called it done.
New exhaust down pipe seals at top, old seals at bottom, nuts, antiseize, and tools of war. Ended up not needing the flare crows foot.
Driver's side down pipe securely fastened to the manifold again.
Passenger's side down pipe securely fastened to the manifold again.
Last step for the exhaust was to install a new GM 213866 oxygen sensor in the passenger's side down pipe and connect the wiring plug.
New heated oxygen sensor at top, still functioning 123,*** mile sensor at bottom.
Nope: forgot a step.
I reconnected the front drive shaft to the front axle. I had to turn the input yoke a touch to get the U-joint to line up, but I got it.
Front drive shaft and U-joint back where they belong.
ASG-MikeS
