Just Fishing
Can't fix stupid
Utah
I can't decide if the bypass is a good idea or not.
I guess it could destroy the filter if it's totally plugged and release all of the badness.
Or it could just block oil flow.
Sparksalot
Bastrop County, Texas
The left rear window quit working on thecopcar. I figured, no biggie, the switch probably bounced loose since it’s dangling. Not quite. I’ve got double baggies on both rear switches to keep them dry and allow me to use the windows. Turns out the left side filled with water. Well crap. Probably shot now. But the kicker was, it was very warm to the touch when I disconnected it.
it’s out of the ** now. Contact cleaner liberally sprayed into the connector to hopefully displace the water as it dries.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Out of the what? Sack? Hole? Nipple?
wsteele
So I got my emissions test notice today and happened to be out running errands, so pulled in to a station and had it tested. They check for completed monitors (1 allowed to not be ready, typically the evap according to the expert). They also checked for DTC's. Finally they did the up the skirt mirror check for cats.
I asked the guy how often he checks for cats being physically there and he said always. No removing the cats in Idaho, or maybe no removing the cats in ADA county Idaho, not sure it is statewide.
*******! You can add whatever expletives you like there!
Sparksalot
I looked closer, one of the pins was left in the socket. so preemptively looked at the other side. Not hot but the pin was broken off too. yay, no rear windows working.
Bill 1960
Testing the Limits
How did they install the filter?
Wrong filter, not tight enough, too tight, cross threaded?
All I can say for now is it’s not loose. Tomorrow with new filter in hand I will get the rest of the story.
08z71bgm
Long Island, NY
Happen to have a link to that book?
And i have a wideband for my vette, the innovative 2 one.
Got it for a great deal on Amazon years ago.
Was a sealed box return, little more than 50% off.
I have spent way more than that in o2 sensor replacements since then.
Seems to be a common complaint.
I'm thinking about grabbing the aem one vs gutting it from the vette.
I also want the gauge as a reference.
Only thing holding me back is that i need a second o2 sensor **** on one of the sides.
And that means the y pipe needs to come off for my welder.
I think the gauge will also help me think in lambda... lol
You don’t need to weld or drill anything. Disable the rear o2 and use the same ******** for the wideband.
Look up erm performance tuning. I forgot who owns the rights now since he passed away.
pwtr02ss
Tennessee
Whaaa. I never thought of doing that. I thought they had to be up high and before the cat. Obviously I've never looked into this much
alpha_omega
Michigan
I’ve been gone a while trying to wrap things up with a house I just recently closed on. Now I finally have some time to get back to working on the Denali.
Read end is done (Diff Cover, sway bar links, bushing, brackets, bolts, track bar) - photos to follow.
Trans Pan, trans flush, filter, transfer case. Between the broken dipstick tube introducing dirt/debris and the previous owner never changing the fluid, I’m worried how long my transmission is going to last.
Question for those Tech2 owners. Can you use the SD flash card on any device and make it a “Tech2” or is there something specific that’s needed which the Tech2 (or look-alike) “body/computer” has? The reason I’m asking is because I have an Autel that has been a great unit for working on all kinds of vehicles, and am wondering if I can use it loaded with the latest Tech2 flash card.
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
Sorry, but you can’t use the card for the tech2 in your Autel.
avalonandl
Troy, MICH & Naples, FL
You are not kidding, my brother in laws boat had (sold it last year) twin mer 500, those boats are a blast to drive.
The Promax 300 are basically the 300 hp version of the old racing 2 strokes. Well known to make 325+ hp but thirsty. I thought the old 2 stroke Yamahas on our 34 ft Intrepid were thirsty.... These Mercs have power up the A$$ but omg the fuel usage.....
My Donzi is a 35 ZF center console and does about 55 mph even with t top and radar dome.
So, tell me if have this right. You want to copy the contents of the Tech 2 memory card onto an SD card, to install in your Autel? And be able to use the Tech 2 software from the SD card?
dizhai
