Tell me why I need a Tech 2.
adventurenali92
Big Bear Lake, ca
I just bought a tech2 as well, came from obd2eshop.com. Came out to $347 shipped. Was a bit expensive but it was the cheapest option I could find, AND I had it in less than a week. Ordered it last Sunday night, it shipped out Tuesday, and DHL said they would deliver it the following Tuesday, a week time frame. I thought that’s fair. Not too long on shipping. It showed up three days later, last Friday! I’ve tested it out. I’m confused on the TIS2000 software as well. It wouldn’t download to my laptop. Also, what does the CANDi module do?
CaptainAmerica1
Arlington TX
The only catch that I know with the ChinaClone versions is -SOMETIMES- they dont actually make it into the US. USBC (US Border and Customs) has been stopping some from making it in. A few members on GMTNation had this issue.
That being said, I just bought my Tech2 a few weeks ago. Have already used it to diagnose what specifically is wrong with my Z55, and my chime. Paid 280 for it, already saved me $120 diag fee at my local dealer.
I know I will need it eventually for my Wifes Aztek, as they seem to eat BCM's. So I know I will eventually come out very ahead.
I still have a cheaper TOPDON Elite model, for MIL, ABS, and SRS codes. But for anything more than "resetting the light" I will break out the Tech2.
I swear to god if it gets lost I’m gonna find you….
petethepug
Michael
SoCal
That same seller is on eBay however they do not sell the Tech II there. I got my Tech II from their shop in China without issues last year.
https://www.ebay.com/str/Chinacardiag/Car-diagnostic-tool-/_i.html?_storecat=3025941013
kbuskill
NE. FL.
The TIS2000 software is good for programming modules in most 2007 and older vehicles as it has the software updates on the cd. For 2008 and up you need to subscribe to TDS.
The CANDI module is for use in any of the GM Vehicles that use a CanBus system. As an example the GMT900 platform (2007-2014 Tahoes/Suburbans/Escalades) requires the use of the CANDI module, while GMT800 platform (2000-2006 T/S/E) does NOT require the CANDI module.
You can leave the CANDI module plugged into the Tech2 and, if the vehicle doesn't require it, it will just act as a pass through.
adventurenali92
Big Bear Lake, ca
thanks for the response!
Lol I can’t even figure out how to connect it to the tech2.... :confused:
so can I connect the tech2 without the CANDi module?
i will try and get the TIS2000 software sorted out in case I need to program any modules down the road. Haven’t needed to yet but ya never know! gonna hold onto the CANDi module because probably gonna end up with a GMT900 in the next yearish so I’m gonna need it. Lol
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
I don’t think tis2000 will run on win10. I had to install a virtual pc on my laptop to get it to work.
Lots of info in this thread. I struggled through the tis2000 stuff starting on post 446.
https://www.tahoeyukonforum.com/threads/tech-2-purchase.111719/page-47
I went to a lot of trouble getting Tis2000 to work, it only runs in XP not Win8 or 10 so you have to run in compatibility mode. Then I found out it’s easier to use the online version for programming so I don’t use Tis2000. Your truck doesn’t need the CanDi module, it’s for the CANBUS systems so yeah hold onto it along with all those other adapters you don’t need.
George B
¯\_(ツ)_/¯
I must have missed that online program. Refresh my memory.
I'll let others more knowledgeable than me answer your question in detail. But, I can tell you that I used the online program to program my replacement BCM, when I replaced the original one, and I did not have to install or use any of the supplied software from the Tech 2 purchase on my computer.
adventurenali92
Big Bear Lake, ca
How do I do the online mode! So I need to subscribe to it?
Yes it’s $40 to program all the modules for one VIN for 24 months. So don’t subscribe until you’re ready to program a module. If you’re planning on moving up to the GMT900 platform with a different vehicle like you mentioned then obviously wait until you do that. But at $20 a year per VIN it’s cheap.
adventurenali92
Big Bear Lake, ca
Yeah that’s definitely cheap! I’ll be holding onto that link. Lol
tis2000 craps out after xp 32bit, so unless you have a dedicated older computer/laptop or run a xp shell (which is slow as ****) then it's not really worth messing with. I suppose there is a need for certain people but unless you have to use it I wouldn't bother. If you do have to use it I would recommend a older pc with max memory and a ssd hard drive, stock windows xp 32bit, has to have a serial port or usb support for a usb to serial adapter. It's probably going to need service pack 2 as well. tis2000 normally needs a dongle but the crack file fixes that.
vdesolution
