Taheezy_88
- Joined
- Feb 15, 2021
- Posts
- 106
- Reaction score
- 65
Sadly I didn't prime my oil pump
Sent from my SM-S215DL using Tapatalk
Will do but if holding key to start wouldn't the car start? Or does the pedal pressed down flood it to where it won't start?When you go to start it, you can hold the accelerator pedal to the floor while you hold the key to "start". It'll crank for about 10 seconds then stop. Let go of the key and pedal to let the starter cool for a couple of minutes. Repeat once or twice more until you see something on the oil pressure gauge then release the pedal and start it as normal.
Wasn't exactly sure what you needed so I just copy and pasted a bunch of things.
Rack and Pinion Gear Adjuster Lock Nut - 50 lb ft
Rack and Pinion Gear Cylinder Line Fitting - 14 lb ft
Rack and Pinion Gear Cylinder Line Retaining Plate Screw. - 106 lb in
Rack and Pinion Gear Inner Tie Rod End Jam Nut. - 55 lb ft
Rack and Pinion Gear Inner Tie Rod End to Steering Gear - 74 lb ft
Rack and Pinion Gear Outer Tie Rod End Nut - 44 lb ft
Rack and Pinion Gear to Frame Bolts-Left Side - 148 lb ft
Rack and Pinion Gear to Frame Bolts-Right Side - 74 lb ft
Front cross member 89 ft/lb (apply threadlocker GM P/N 12345493)
Inboard Flange Bolts - 58 lb
Thanks
The opposite. Holding the pedal to the floor is actually a factory "clear flood" function. It lets the engine crank but without firing the injectors or ignition coils. The engine spinning will turn the oil pump slowly, but enough to eventually push oil through the system.
I learn't sumptin from you today bro, thanks. ((((hugs))))
#1... Stabilitrac light could be/probably is on because of the misfires.
#2... Could be dirty injectors, could be a bad coil pack harness, could be a bad coil pack or plug wire, could be a burnt valve although that is unlikely as the machine shop would have probably caught it. I always have them pull a vacuum on the heads/valves to make sure they are sealing well.
#3... Could be bad cam bearings but I would check the seals on the towers under the VLOM/valley cover. Not sure if you replaced/removed the screen under the oil pressure sensor.
I didn't go back and reread the 10 pages to see if any of this was already covered... just the first things that came to mind.
Would running straight headers cause this?
I don't have the y pipe bolted up to the headers yet. I was also getting a lean code. Could it be because the o2 sensors are not hooked up/y-pipe and the engine running lean cause the misfires?
Downstream I assume the ones that hook on the cats.
