2007 Tahoe 5.3l AFM DOD delete thread
Taheezy_88
Taheezy_88
Sadly I didn't prime my oil pump
Sent from my SM-S215DL using Tapatalk
When you go to start it, you can hold the accelerator pedal to the floor while you hold the key to "start". It'll crank for about 10 seconds then stop. Let go of the key and pedal to let the starter cool for a couple of minutes. Repeat once or twice more until you see something on the oil pressure gauge then release the pedal and start it as normal.
Taheezy_88
Taheezy_88
Will do but if holding key to start wouldn't the car start? Or does the pedal pressed down flood it to where it won't start?
Taheezy_88
Taheezy_88
Anyone got the torque specs for the:
Rack and pinion?
Front crossmember?
Drive axle 6 bolts to differential?
Worried to drive and can't find the torque specs unless they are just
Tighten them as much as you can.
wsteele
Wasn't exactly sure what you needed so I just copy and pasted a bunch of things.
Rack and Pinion Gear Adjuster Lock Nut - 50 lb ft
Rack and Pinion Gear Cylinder Line Fitting - 14 lb ft
Rack and Pinion Gear Cylinder Line Retaining Plate Screw. - 106 lb in
Rack and Pinion Gear Inner Tie Rod End Jam Nut. - 55 lb ft
Rack and Pinion Gear Inner Tie Rod End to Steering Gear - 74 lb ft
Rack and Pinion Gear Outer Tie Rod End Nut - 44 lb ft
Rack and Pinion Gear to Frame Bolts-Left Side - 148 lb ft
Rack and Pinion Gear to Frame Bolts-Right Side - 74 lb ft
Front cross member 89 ft/lb (apply threadlocker GM P/N 12345493)
Inboard Flange Bolts - 58 lb ft
sonic_the_hedgeh
Should put a legend at the bottom. Lmao.
Did
Lfm
Tbl
Lrp
Cgw
No idea but what these mean
Sent from my LM-V600 using Tapatalk
Taheezy_88
Taheezy_88
Thanks
The opposite. Holding the pedal to the floor is actually a factory "clear flood" function. It lets the engine crank but without firing the injectors or ignition coils. The engine spinning will turn the oil pump slowly, but enough to eventually push oil through the system.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
I learn't sumptin from you today bro, thanks. ((((hugs))))
This is a handy feature for those with an ailing lifter that ticks at startup but quiets down after oil pressure builds. With mine sitting for 1-3 weeks at a time, I had a pissed off lifter when I went to crank it. I started cranking it for about 20 seconds before releasing the pedal to crank it as normal to lube the lifters a little. It really helped the ticking. Not a single tick since the AFM delete, though.
Taheezy_88
Taheezy_88
Alright guys after a long process and having to put off the project due to traveling and etc... I finally got it started and running. I do have three things that concern me.
1) Stabilitrak light is still on. Why could this be?
2) p300 engine misfire code. This worries me any reason why I could be getting this misfire? Put new plugs in this morning before start up
3) oil pressure fluctuates. 40 when I rev the engine but drops low when idle. Any opinions? (Posted pics)
kbuskill
NE. FL.
#1... Stabilitrac light could be/probably is on because of the misfires.
#2... Could be dirty injectors, could be a bad coil pack harness, could be a bad coil pack or plug wire, could be a burnt valve although that is unlikely as the machine shop would have probably caught it. I always have them pull a vacuum on the heads/valves to make sure they are sealing well.
#3... Could be bad cam bearings but I would check the seals on the towers under the VLOM/valley cover. Not sure if you replaced/removed the screen under the oil pressure sensor.
I didn't go back and reread the 10 pages to see if any of this was already covered... just the first things that came to mind.
Taheezy_88
Taheezy_88
Taheezy_88
Taheezy_88
2) plugs and wires are new. I'd have to replace coil packs, injectors would running a fuel system cleaner fix that?
3) I did remove the small oil screen filter because it wasn't fitting with the new vlom and read somewhere on a GM site that running without doesn't hurt but of course I could be wrong or that source.
What should be my first steps to solving the issues? Pull VLOM check towers? Replace Coil packs, and try to reinstall the oil filter while I have vlom pulled
Taheezy_88
Taheezy_88
Would running straight headers cause this?
I don't have the y pipe bolted up to the headers yet. I was also getting a lean code. Could it be because the o2 sensors are not hooked up/y-pipe and the engine running lean cause the misfires?
kbuskill
NE. FL.
A good scanner that can show misfire history would help narrow down the culprit. You could try swapping coil packs to see if the misfire moves with the coil pack.
You don't have your upstream O2 sensors hooked up? Or downstream O2 sensors?
Taheezy_88
Taheezy_88
Downstream I assume the ones that hook on the cats.
wsteele
If the upstream O2 sensors aren’t there or one has a fault, it can lead to misfires.
If you have a scan tool, try and find the cylinder misfire count page and watch it while running the engine. You can see real-time which cylinders are misfiring and how often. It can help you isolate the problem to one bank or the other and after that, which cylinders.
If both banks have a lot of misfires, that too can help in isolating the issue.
Taheezy_88
Taheezy_88
The 02sensors closest to the headers so my upstream sensors are unplugged. Let me get the ypipe and upstream 02 sensors hooked up. I hope that's the issue what yall think?
johnsonwillie199
