Newbie intro, 6" RC lift, 22 OEM chrome, 35" MTs
DADW4GN
DADW4GN
Kansas City, MO
Just updates dropping here for build reference: added in-line speedo correction, pedal commander, and rgb rock lights.
Pedal commander really woke up the throttle response. Leaving set at Sport mode +2 for now. Excellent on demand power, much more indicative of true power train potential.
Rock ligjts...meh...spent a ton of time on install making it clean, but end result is a bit too flashy for me. I typically leave it at a lower light amber setting if I turn them on.
Rock lights make you need to detail your wheel wells. I decided no lol.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Looks like they would be great for a roadside repair at night though!
STORMIN08
In regards to the pedal commander...do you also have a tune of any kind ?
I recently installed a Diablo intune, currently set on the 87 octane tune with the following..
Tps increase 15%
Up shift psi increase 15%
Dod is off
The vehicle is night and day different in terms of drive ability. Always hated the early up shift feel, and now that is corrected...partially TPS and partly increase in pressure.
I may try a stock tune and just increase TPS just to see.
DADW4GN
DADW4GN
Kansas City, MO
Tps increase 15%
Dod is off
No, I went with the pedal commander because it is an in-line option. I don't want to add any tune footprints to the computer, because I'm mid 40k in mileage, and not wanting to risk warranty issues.
That's the only thing about the regear that sucks, no more cruise control because the timing of the gears and sensors don't match up. A tune would be about the only thing that would take care of that, but I'll wait for 75k miles.
DADW4GN
DADW4GN
Kansas City, MO
Well, ordered the Curt 17500 weight distribution hitch system, and 7" drop shank, but one of the anti sway bars was missing from the box. Amazon is sending a new system out Tuesday and picking up the one I received.
So had to go with a simple drop hitch this weekend for an offroad trip with my cruiser club. About an 8700 pound setup. A lot of tongue weight made it droop a bit, but it towed really well. The WD system will be even better, and I'll have that for the run out to Moab. I don't expect to be fast up the passes, just safe and capable.
olyelr
Elk Rapids, MI
View attachment 277619 View attachment 277620
heck yea!
is 7” enough drop?! The hitches on these rigs are super high in stock location...cant imagine what it is with a 6” and 35’s lol
DADW4GN
DADW4GN
Kansas City, MO
heck yea!
Will find out this weekend when I test fit. I got the setup from a contact in my Missouri campers forum that built a Sema 1500 pickup. He's at 9" of lift and uses an 8" drop with the same Curt system. I figured 7" should do me. The simple drop hitch I used was a 4" drop. I do like to leave some tongue weight when I pull, just feels like trailer pulls better / stays straighter.
DADW4GN
DADW4GN
Kansas City, MO
Made it to Moab. Thankful for gears, airbags, and WD hitch; made it up the pass and back down without issues. 7" drop was perfect and set the WD hitch angled down 2 settings. Brought everything nice and level, and pulled really well. About 9,000 lbs in tow.
20210512_110400.jpg 20210512_203341.jpg 20210512_203310.jpg 20210512_203326.jpg
Superslow
I'm looking to get a similar setup for my Yukon, but I do have to still get it into parking garages. Would you mind measuring the total height of the vehicle pretty please!
DADW4GN
DADW4GN
Kansas City, MO
On a lake trip currently, but I should have a tape in the truck. Will try to remember to check in the morning.
maxpsi
4.10 Nitro gears going in today and tomorrow.
Factory set had a surprising amount of wear!I Like more wear than we typically see when regearing our 200k mileage 80 series Land Cruisers, which was a little alarming. My hunch is the lift and tires over the last 6,000 miles coupled with using "auto" 4x4 frequently on wet or slick pavement through the winter. One of the local 4x4 shops told my buddy to stay away from the "auto" setting on his Tahoe Premier with 6" inch lift, and to just use 4hi as needed in snow or dirt. And I will say, it did growl a bit in the auto selection on the freeway. I just figured it was more the drive shaft and planned on going double cardan. My hunch is that it was ******* the rear gears. So I will probably stay away from the dummy switch and dedicate 2 or 4 wheel based on conditions.
Rear needed one adjustment at install.
View attachment 273016 View attachment 273017 View attachment 273018 View attachment 273019 View attachment 273020
Still liking these gears? Are you still running the gov-lock?
Drewphil
