What do i need to recalibrate my speedometer after my tire/rim swap?
totalpackage
So i am registering about 4 mph slower than i am actually travelling. What tool or electronic device do i need to make the change?
2010 LS Tahoe
wsteele
2010 LS Tahoe
The guy who sold you the new tire/rim package may have a scan tool sophisticated enough to do that.
As stated above Black Bear tuners can do it, a Diablo Predator can do it, you may have a member here close enough to drive to, who owns a Tech 2 that can do it for you as well.
Where you located?
wsteele
So i have been quoted $100.00 to make the adjustment. I can buy this for $360.00.
https://www.amazon.com/DiabloSport-...1-2676-104-3&vehicleName=2010+Chevrolet+Tahoe
Does anyone know of a more inexpensive tool?
East Tennessee
Maybe someone reading this thread close to you who has a Tech 2 will respond. It certainly isn’t an hour of labor time, more like 10min.
You might also call around to tire shops in your area that do a lot of aftermarket sales, a commercial scan tool probably can get it done cheaper than $100.
Frankly, you can buy a Tech 2 clone for less than $360. Of course, you can’t turn AFM off with a Tech 2, so...
Super Moderator
Elev 5,280
I thought the Tech 2 tire size setting did not affect the speedometer. (?)
wsteele
I frankly don't know, I assumed it did, but perhaps the factory assumes everyone is only going to run stock tires. Other than wheel speed calibrations for ABS/traction control, why would they even include it as something you can change if it didn't affect speedo calibration?
I swore I wasn't going to pick mine up for a while, as I already have sunk too much time into it, but maybe just this once... :)
wsteele
I am sitting right in front of my Tech 2 and can’t find where it even takes tire size data. I swear I saw it, but it might have been one of my training videos I watched, which use a lot of different type cars for examples.
In any case, right now it looks like you are right, a Tech 2 might not do it, at least on these trucks. I know it does it on some GM vehicle, but maybe not the trucks. Now more time on YouTube finding the video I know I watched. :(
So for now, for the OP, maybe find someone local that uses HP Tuners?
wsteele
So I found the instruction video I watched on the Tech 2 setting tire size and it was a freaking Saab. :(
I went through most of the pages on my Tech 2 and didn't find anywhere that it would calibrate the speedo off tire size.
Looking for the Tech 2 video, I did see a bunch of aftermarket devices that will reprogram the speedo calibration based on tire size that are a lot less expensive than a Diablo Predator. I think it will still be more than the $100 quote you already have in hand. Sorry for the bad advice on the Tech 2.
Luggz
